-   -   Draft Inducer Motor Assembly (http://www.diychatroom.com/f17/draft-inducer-motor-assembly-130268/)
70Flyer 01-16-2012 07:22 PM
I am looking for the part number for a Draft Inducer Motor Assembly. My furnace is a Carrier Weathermaker SX, Model Number 58SXA120--101LG, installed in Novemer 1991. The inducer motor part number is JA1P077N, 115Vac, 60Hz, 1.75A, 3300rpm, 0.050hp. The motor is running hot and I want to replace the entire assembly rather than just the motor (motor, blower, housing, etc). Can someone please identify the assembly part number and a possible vendor?
Thank You,
70Flyer
hvac5646 01-16-2012 07:33 PM
That old a unit they sold the components separately. Not as a whole assembly...unless they have changed....
hvac5646 01-16-2012 07:40 PM
just ran the numbers you gave and neither came up.
Need the mod and serial....the complete numbers
biggles 01-16-2012 08:20 PM
check here for reference numbers with model off the unit http://www.bestbuyheatingandaircondi...ode=fasco-indb
Doc Holliday 01-16-2012 08:23 PM
http://i21.geccdn.net/site/images/gr...ge/PAC_579.jpg
A.O. Smith 3.3" Shaded Pole Draft Inducer Motor - 3300 RPM 115 Volts
Item #: T9AB186257
Doc Holliday 01-16-2012 08:24 PM
call these guys and give them your info. http://www.globalindustrial.com/productFinder
harleyrider 01-16-2012 09:44 PM
really? thats funny I have 15 in stock as we speak.....
diyorpay 01-16-2012 11:36 PM
The fasco catalog:
http://www.fasco.com/prodcat.asp
hvac5646 01-17-2012 10:34 AM
What do you have in stock ...? 15 motors or 15 motor mounts?
That blower was not fixed to the mount like todays inducers.
That furnace is very old and I don't think that stocking a motor that has one app (and especially since it is 3300RPM) would be something I would tie up money in stocking.
I don't remember when the last time was I even saw one. Most have been replaced.
70Flyer 01-20-2012 12:00 PM
Draft inducer Motor Assembly
Thanks for all the replies. I still have not located a complete Draft Inducer Motor Assembly. Here are the details again:
Item: Draft Inducer Motor Assembly
Furnace: Carrier Weathermaker SX, Upflow Furnace, Series 100
Model Number: 58SXA120--101LG (this is the exact number, no other #s)
Serial Number: 3091A03591 (not provided in first post)
Installed: November 1991
Inducer Motor Part Number: JA1P077N, 115Vac, 60Hz, 1.75A, 3300rpm, 0.050hp.
There are no other numbers on the furnace or inducer motor assembly.
The motor is running hot. I located a replacement motor itself, but I want to replace the entire assembly (motor, blower, housing, etc.) rather than just the motor alone.
The reply from "HarleyRider" stated that he had 15 in stock, but I don't know if he means 15 motors or 15 assemblies. If he has the entire assembly, I would be interested in buying one.
I contacted Carrier directly, and they would not provide the part number. They told me to go to one of their dealers.
Again, any help is appreciated.
70flyer
how 01-20-2012 12:23 PM
Hey 70 flyer
You know those motors normally run hot. What measurement is making you nervous? An Amp measurement against the spec's is the better test to worry over.
70Flyer 01-20-2012 12:38 PM
I have religiously maintained this furnace over its 20 year life. I clean the inside of the furnace every 4 months with a soft brush, shop vac and blower. On December 30, a service technician performed the normal annual maintenance on the furnace. He said that the motor is rated for 1.75A max, and that it is drawing 1.85A measured. So, it is about 0.10A over the maximum expected current. This may not be enough to make it run hotter than normal. It may be a sign that the bearings are about to seize. I don't have any data from the previous maintenance activities because they did not measure the inducer motor current separately. They usually measure the blower motor current only. The technician measured the inducer motor current this time because the motor felt hot to him.
70Flyer
harleyrider 01-20-2012 12:59 PM
70flyer
Part number 309868755, it is a whole assembly.
70Flyer 01-20-2012 02:11 PM
HarleyRider,
Thank you for the part number. If you have the Inducer Motor Assembly, Part Number 309868755, what is price and shipping cost to Pittsburgh, PA? I have pictures of my Inducer Motor Assembly, but the file size is too large to attach. I can email to you if you provide your email address.
Thanks Again,
70Flyer
harleyrider 01-20-2012 03:43 PM
send me a Private message
