Old 12-03-2011, 08:21 PM   #1
Draft Inducer
I have a Kenmore furnace and the inducer make a lot of noise and it looks like that i need to replace it , the unit number is 7062-3719 which i cannot find it anywhere, any idea??
Joeav is offline   Reply With Quote
Old 12-03-2011, 08:52 PM   #2
biggles's Avatar
Draft Inducer
make sure the squirrel cage didn't shift over and is rubbing free spin it both ways.... does it brake hard stop or roll stop? WD40 into the motor shaft area spin it...work it in... check here http://www.bestbuyheatingandaircondi...ode=fasco-indb check Grainger site
Old 12-03-2011, 09:07 PM   #3
Draft Inducer
is this an 80% or 90% model # think its tempstar by inner city products labled for sears....
Old 12-03-2011, 09:23 PM   #4
Draft Inducer
Find the right one here:
http://www.fasco.com/documents/pgs068-095.pdf
http://www.fasco.com/documents/pgs051-059.pdf
Then order someplace like here
http://www.cshincorporated.com
Not that difficult for a handy DIYer.
Good Luck
diyorpay is offline   Reply With Quote
Old 12-04-2011, 02:32 AM   #5
REP
Draft Inducer
Its a Sears unit,you get the replacement fan assembly at Sears .And yes get the assy and not just the motor.
REP is online now   Reply With Quote
Draft Inducer Blower Not Blowing- LED Blinking 3 Times rust101 HVAC 10 04-09-2013 09:44 PM
Draft Inducer Squealing Noise rbh123456789 HVAC 9 01-05-2012 01:37 PM
Draft Inducer running all the time. jimreed02 HVAC 5 03-18-2011 04:51 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 03:10 PM
