Down Shot Burners - HVAC - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 06:51 PM   #1
Rewards Points: 150
down shot burners
can a Multi positional furnace be installed so the burners are shooting straight down against gravity? I would think there would be an air flow problem or something but not sure.
wetbar is offline   Reply With Quote
Old 06-21-2013, 09:16 PM   #2
I've never seen laying on its back an option in the install manual.
The Following User Says Thank You to Marty S. For This Useful Post:
hvactech126 (06-22-2013)
Old 06-21-2013, 10:17 PM   #3
Rewards Points: 150
we came across one today. The customer said it worked last year, but I have never seen one either. Once the draft fan gets just a little weak this thing has to start popping roll outs.
Old 06-21-2013, 11:51 PM   #4
Rewards Points: 446
There isn't one out there that I'm aware of that allows for this kind of installation. If you're a contractor I hope you have model # at least to research the option and if it's not allowed you get back to the customer and get the furnace shutdown until it's installed correctly. Being the last one there, when something bad happens, you're the one the lawyers are going to be looking for.
old_squid is offline   Reply With Quote
The Following 3 Users Say Thank You to old_squid For This Useful Post:
hvactech126 (06-22-2013), Marty S. (06-22-2013), yuri (06-22-2013)
Old 06-22-2013, 07:19 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 2,308
Does NOT meet the gas code or UL rating/approval if done that way. There are pics with clearances to combustibles and approved ductwork connections in the manual and the gas inspector ( if he is not some idiot Bubba) should have caught that. As a Pro if you have a license you could get in trouble later, No license then no problem or less of one. Could get some serious delayed ignition/backfiring if the burners get dirty or the HSI gets weak.
Old 06-23-2013, 12:49 PM   #6
Rewards Points: 150
We shut of the gas and told the customer we wold come back out in the fall to flip this thing around. That way when we left it was shut off and if he calls some other company instead of us, it will be their problem if something happens, not ours!
Thanks for the input
Old 06-23-2013, 03:06 PM   #7
Hvac Pro
yuri's Avatar
as long as you wrote that on your invoice and got it signed then U R OK. DO NOT trust anyone, I have been backstabbed so many times it is disgusting.
Furnace Burners Flicker On and Off EDOinHB HVAC 19 02-22-2012 05:55 PM
Furnace burners will shut off after 10 mins Liberator HVAC 10 01-20-2012 10:23 AM
Burners won't all light Vern Clanton HVAC 9 12-28-2011 04:38 PM
main burners cut out/ no automatic vent damper? Shevek HVAC 6 11-14-2011 12:33 AM
Burners quit during heat cycle kaw11 HVAC 4 01-24-2009 03:29 PM
