Down Draft Issues - Woodstove - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 09:31 PM   #16
Rewards Points: 150
Try chimneys.com
bernieb is offline   Reply With Quote
Old 04-04-2011, 10:00 PM   #17
Originally Posted by Artco
It was and then i built a room and part of the pipe was then inside and it did help a little but the slight smoke and odor was always there. I finally got discusted and put in a pellet stove and that worked.
I know the frustration he is going thru.
What made the pellet stove work?
Fantastic is offline   Reply With Quote
Old 04-04-2011, 10:46 PM   #18
internal forced draft motor
Artco is offline   Reply With Quote
Old 04-05-2011, 12:20 PM   #19
You might want to ask your question at Hearth dot com. There are a lot of people there who really know stoves. I'm not one of them, but here are some ideas running through my head:
That chimney on the outside of the house is double wall insulated pipe, right? Feels solid if you thump it? Usually you have problems with chimney's not drafting because they're A) too short, or B) too cold (not insulated). But if that's insulated pipe, then you don't seem to have either problem.
On your picture you label the thing on the stove pipe as a "thermostat." Did you really mean thermometer? As in something that's just stuck on the pipe? If there's something inside the pipe there you may have found your problem.
My stove only has about 10' of chimney (plus six feet of stove pipe) and the draft is excellent.
Your two 90 degree bends are hurting you. I don't see the trees making any difference -- it's not about wind, it's about warm air rising. It doesn't seem like adding another section of chimney would help dramatically, and you would probably need to support it (three steel wires).
If you have cold air dropping down the pipe, then were is the warm air going that it is displacing? Opening the windows will probably aggravate your situation, because the heat in the room will rise out of them, and suck more cold air down the pipe.
What do you use to start your fire? Next time start one with a lot of good, dry kindling. The idea being to get as much heat with as little smoke up the chimney as quickly as possible.
Where does the smoke exit the stove?
pyper is offline   Reply With Quote
Old 04-05-2011, 12:25 PM   #20
Experienced
Jackofall1's Avatar
The insulation in "A"-vent is an 1" air space, the flue piping is not packed with insulation. This is why the chimney can't get hot enough to start the draft.
Mark
Old 04-05-2011, 12:39 PM   #21
The pipe outside looks like "all fuel chimney" to me. The pipe when not being used gets just as cold as it is outside.
If the pipe is on the north side in the shade it stays cold. The higher the pipe the harder to create a draft.
All fuel chimney has insulation inside and is very heavy and i believe only comes in 30" lengths.
Old 04-05-2011, 02:44 PM   #22
An old Tradesmen
Rewards Points: 7,332
What size is the chimney, and what size is the stove pipe?
Old 04-05-2011, 03:29 PM   #23
Mark
Mine is insulated. My chimney has an inch of mineral wool between two layers of steel. It stays cool to the touch, even when there is a raging fire burning. According to this guy, they all are:
http://www.inspectapedia.com/chimney...A_Chimneys.htm
Old 04-05-2011, 03:38 PM   #24
He has not said what type pipe he has installed. It may be the insulated pipe.
Old 04-05-2011, 03:46 PM   #25
Rewards Points: 380
Do you have another chimney in the house? Is it higher than this one? They will often work against each other if you do.
HVACDave is offline   Reply With Quote
Old 04-05-2011, 07:01 PM   #26
HVAC / Plumbing
If he comes nack . I would like to know if it smokes up the house with the stove doors open or with doors closed or both
kenmac is offline   Reply With Quote
Old 04-05-2011, 08:25 PM   #27
Yes. Double wall insulated.
Yes, thermometer. It's a magnetic one stuck on the pipe.
I used very dry cedar and cardboard.
Through the back and through the damper.
Old 04-05-2011, 08:28 PM   #28
Yes. There are 3. One for the furnace and hot water heater(oil) and the 3rd probably doesn't matter as it is for a propane furnace in the garage.
Old 04-05-2011, 08:29 PM   #29
Both.
Old 04-05-2011, 08:45 PM   #30
An old Tradesmen
And the size of the chimney is?
House settling issues gmvshort Building & Construction 3 02-22-2011 06:26 AM
induced draft on same flue as natural draft Skippymartinez HVAC 1 12-08-2009 06:14 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 02:10 PM
