Old 12-28-2010, 10:31 AM   #1
Down Draft on Exhaust Vent causing incomplete ignition???
I have 2 80% efficient Gas Furnaces that periodically do not ignite or does not ignite completely causing gas to leak into attic and house. I have had gas company out twice to check for leaks and pressure both are OK. HVAC contractor has been out 3 times, cleaned burners, replaced gas valve on one furnace and now thinks downdrafts from roof vents is preventing furnace from ignighting when it is windy outside. Last time this happened it was very windy can't remember on the other events. This started before Thanksgiving and occurs about once a week. Does the latest explanation make sence with 80% furnace with induced fan ignition? Contractor is recommending replacing roof vent caps.
tigerfan is offline   Reply With Quote
Old 12-28-2010, 10:51 PM   #2
30 year tech
hvac122's Avatar
It does make sense. You may try raising the flue up a few feet also. It would be nice if the tech could see it happening instead of guessing but it does turn out that way sometimes. Could also be something else also.
hvac122 is offline   Reply With Quote
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
drawing of studor vent in branch not stack - causing flush issues? ejleonard Plumbing 3 06-30-2009 07:19 PM
Bathroom exhaust fan causing ice dam Arton Roofing 5 01-30-2009 05:35 PM
extending my direct vent exhaust tube brianbh HVAC 5 02-13-2008 04:25 PM
