Old 11-19-2009, 11:32 AM   #1
down draft
hello, i have to stainless chimneys side by side one wood and one oil. when 1 is being used there is a down draft inthe other. any body have any advice, it would be greatly appreciated. to explain further, when im burning wood i get smoke coming bak down through the damper on my oil chimney.
roadhouse is offline   Reply With Quote
Old 11-19-2009, 11:48 AM   #2
An old Tradesmen
down draft
Sounds like you have a tight house. And don't have enough make up air for your stove, and or oil stove.furnace.
Add a make up air vent.
Old 11-19-2009, 11:55 AM   #3
down draft
what do you meen by a make up air vent
Old 11-19-2009, 12:00 PM   #4
An old Tradesmen
down draft
In order for the wood or oil to burn. It needs air. That air comes from your house. After so much is burned with teh fuel. New air must come into the house to replace it.
in your home. that new air is coming from the opposite chimney. So you need to provide another way/method for the air to be replaced. Its known as make up air, or combustion air intake.
Old 11-19-2009, 07:31 PM   #5
down draft
thank you. so whats the best way to achieve this air?
Old 11-19-2009, 07:52 PM   #6
An old Tradesmen
down draft
Install an intake close to the wood stove.
Where is the stove located.
Old 11-19-2009, 08:13 PM   #7
down draft
in the basement
Old 11-20-2009, 05:02 AM   #8
An old Tradesmen
down draft
A small intake. Probably a 6". Terminated near the stove.
With either a damper you can shut off when not using the stove.
Some people, just open a window an inch or so.
More On This Topic
Kerosene lamps, also sometimes called hurricane lamps, are nonelectric lamps that came into common use beginning in the 1800s. While most buildings use electric lighting these days, kerosene lamps remain a viable alternative to meet emergency lighting... Read More »
The efficiency of a fireplace depends on several factors. Though the design is certainly important, it isn't the only thing to consider. Adding components and performing routine maintenance are critical to maximizing efficiency. No matter what type of... Read More »
In this segment, we're going to cover removing the air duck. It's a fresh air intake duck and what that does is pull cold fresh air, coming in the automobile from the front and runs it into the air cleaner assembly. The colder, denser air makes for... Read More »
Hi, I'm Bobby on behalf of Expert Village. Everyone loves having a warm fireplace on a cold winter day. The downside to that is that you have to clean the fireplace. In this series we are going to show you how to clean the inside of your fireplace, your... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be replacing our air filter. Before we replace our air filter, we want to take a close look at some of our intake ports here for our air into our carburetor. You want to make sure... Read More »
Draft motor does not turn on simphead HVAC 15 10-29-2009 10:19 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 03:10 PM
cold air draft in wall rob williams General Discussion 4 03-16-2009 10:11 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
