Double Cold Air Return To Nowhere? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 12:43 AM   #1
I ask the impossible!
Rewards Points: 640
double cold air return to nowhere?
It's late so I'll make this short, in the pic below you'll see 2 flexible ducts going into a sheet metal enclosure of a joist cavity. Above this is my stairway, but there's nothing inside that this connects to. The other end of both of these ducts is the cold air return manifold of my furnace.
The duct on the left needs to go because the post shows where a beam will be coming through.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 01-10-2012, 01:05 AM   #2
I will bet if you follow the panning, you will find that they go to a wall or floor return grille. doing away with them will cause your unit to have serious and potentially deadly problems.
harleyrider is offline   Reply With Quote
Old 01-10-2012, 01:10 AM   #3
I'm Your Huckleberry
Rewards Points: 2,270
How many return grills are in your home? You may need to relocate the one versus simply removing it.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-10-2012, 08:14 AM   #4
Rewards Points: 640
Ahh.. okay, now that I've had some sleep I can get into more detail.
So, what is a little hard to see from the picture, the sheet metal enclosing the joist cavity terminates on the left side about where the strap hanging the gas pipe blocks the view. On the right side, it is considerably harder to see - the board that is supporting the floor joists, I haven't accessed the other side to look. Beyond that board is a triple 2x6 center beam, and I know that this enclosed joist cavity does not go to the center beam, so either that side is open or it closes before that. The sheet metal on the bottom has an open gap to the crawlspace at the board visible in the photo.
Assuming it's enclosed on both sides, which is one of those assumptions that should be reasonable - but in the case of this house, I've found that reasonable assumptions are often wrong - this would be a cold air return pulling something from somewhere inside the stair cavity.
Under the stairway to the second floor, there is a metal duct going to the front bedroom wall register. That is not what this is. That duct is served by a seperate duct.
There are no other duct work under the stairs.
For cold air returns, there are 2 returns on the first floor served by seperate ducts. The second floor has 2 supply registers, one in the wall of the front bedroom and the other in the floor of the rear bedroom, both served by their own ducts. There is one other floor grate at the top of the stairs which has no duct work, it's just a floor grate to the joist cavity.
Is it possible that these 2 cold air returns are intended to pull cold air returning from the floor grate on the second floor? Possibly. If that is their intended function, they can't be doing it very well because there are plenty of gaps in the stair treads and a very loose openning into the space under the stairs, and it's not clear what the air path is from the floor grate on the second floor.
One of those ducts has to move or be capped off.
At this point, I have no door to the front bedroom, it split in half at the hinges. I have 7' ceilings upstairs and the door openning is shorter than standard opennings, and in a year or two the whole second floor is coming off, so I'm having a little difficulty justifying to myself putting a new door on.. The other bedroom has a generous gap under it. (and no cold air return in either room anyway)
Old 01-10-2012, 08:33 AM   #5
biggles's Avatar
how far away is the unit from those duct drops the return should basically be under the stat location is within a hallway so the stat can sense that return air..is that a cold crawl space.the back of the furnace should be consistant in size from the space 20 x 20 grilled.if that flex is sitting in a lower temperature area it will chill that return from the space.
Old 01-10-2012, 09:57 AM   #6
Rewards Points: 640
There is a register heating the crawl space off of the heated air manifold. The ducts shown in the picture might be around a 5' run. There aren't really any hallways in the house, the stairs go up to the second floor to a landing that is maybe 30"x30" which has the floor grate in it, and the bedrooms are on the left and right as you are facing from climbing the stairs.
Old 01-10-2012, 10:25 AM   #7
Rewards Points: 640
So I'm thinking I don't know enough to say whether there was a good reason to run 2 cold air return ducts, but regardless it can't be any worse to stick with 2 cold air return ducts, so I will connect them both to a 6" wye and cap off one opening.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old 01-10-2012, 10:31 AM   #8
Every furnace needs a certain amount of return air. One 6" run is nowhere near enough for any furnace.
What size furnace do you have?
Thanks.
Old 01-10-2012, 10:41 AM   #9
This pdf is for heat pump systems but you can get an idea. I'm sure you could search the internet for required cfm (and duct sizes and grill registers to accomodate) for your sized system.
Scroll down to "flex duct return".
http://efficientcomfort.net/Rules_an...ct_Systems.pdf
Thanks.
Old 01-10-2012, 10:45 AM   #10
Rewards Points: 640
I think the 75 in the model number means it's a 75000 BTU unit.
There are 2 more 6" cold air returns besides the two pictured.
Old 01-10-2012, 10:53 AM   #11
I believe 75k btu is a 3 ton.
Here's some more related and interesting info if you care to get very technical.
http://www.mmmfg.com/pdfs/060601_CC-...tTechPaper.pdf
Thanks.
Old 01-10-2012, 12:41 PM   #12
Rewards Points: 1,528
Doc, after reading that study, it seems that anything less than a 4% sag/compression of flex duct in an install would result in significant losses (increased pressure) of air flow vs. rigid metal. Might explain why my second floor bedrooms have such poor airflow:
Flex line squished between air intake/exhaust pipes and floor joist.
Connects to a boot in the wall cavity?
Any way of fixing this?
bob22 is offline   Reply With Quote
Old 01-10-2012, 12:59 PM   #13
biggles's Avatar
that return has to come from the heated space anyplace else and your going to heat raw/unconditioned cold return air maybe bring the register duct out to the flex..instead of cramming that flex in the straighter the return the better the return and al has to be tight...furnace is going to suck air from any place it can... all types of connections on here http://www.bestbuyheatingandaircondi...ctworkmenu.htm
Old 01-10-2012, 01:54 PM   #14
Anything can be fixed, it's how you go about doing it that counts. It's a very poor install to begin with and definitely is an issue with performance, being strangled as it is.
I'd remove that run and put it in it's own joist away from those pipes.
Thanks.
Adding on to cold air return agicr HVAC 13 03-27-2011 02:33 PM
Cold Air Return issue ra1185DIY HVAC 1 12-05-2010 04:21 PM
moving my cold air return Bill Smith Building & Construction 2 11-27-2010 11:35 PM
Need advice on cold air return mrlouie HVAC 4 10-09-2010 05:33 AM
Cold Air Return next to supply duct thebigbbm HVAC 6 09-21-2010 06:51 PM
