Old 01-20-2013, 08:14 PM   #1
Door switch question
Hi,
How much of the furnace's operation is controlled by the door switch?
E.g. can any fans run with it open?
Is the the control board powered down by the switch or is it just one of the safety inputs to the control board?
bausin is offline   Reply With Quote
Old 01-20-2013, 08:16 PM   #2
Originally Posted by bausin View Post
Hi,
all of it ..its shuts off the 120 volt from switch..
Old 01-21-2013, 02:49 PM   #3
I was looking at a neighbor's furnace and saw no LED lit through the viewing hole nor after I took the panel off. I ordered him a new board but then got to wondering if the door switch had been open the whole time (there were three screws missing on the panel). The fan was running before and after I removed the panel. So it's good to know I didn't order a board for nothing. I'll have to check that door switch when I replace the board.
Thanks.
Old 01-21-2013, 02:58 PM   #4
Thanks.
Yeah if the fan was running after you took the door off then someone probably wired around the switch or taped it permanently closed. Because the door switch should turn everything off.
This is why you should never trust a door switch to kill power, always verify power is off. I've been shocked several times because of that or someone wiring the nuetral leg to the door switch instead of hot.
JScotty is offline   Reply With Quote
Old 01-21-2013, 03:46 PM   #5
how
A number of different boards show no led light unless there is an internal fault.
The legend on the furnace door should tell you if the led light should be on.
If the legend only lists fault codes and no code for power then
a stat or stat wiring failure could cause the fan to run continuously with no heat and a properly working board would never show an led light.
Many furnace set ups can also include a continous fan operation.
how is offline   Reply With Quote
Old 01-21-2013, 04:16 PM   #6
The error code table says no LED means Hardware Fault. I don't know what hardware that means. I assumed it meant the board itself so I ordered a new one. I'll know more once I get the new board.
Old 01-21-2013, 04:20 PM   #7
Then you're probably right. If it said no code meant hardware fault that means bad board. Or at least that's how I'd read it. I think you're on the right track
Old 01-21-2013, 05:07 PM   #8
how
Agreed..bad board.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
