Dog Pulled Wires Out.... Help - HVAC - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 08:18 PM   #1
Dog pulled wires out.... Help
My daughter calls me and sends me some pictures of her outside unit after her dog chewed and pulled what looks to be control wires. Perhaps to the inside unit or thermostat. Idk.
But, where do I hook them up? Where are the terminals and any ideas where they would land? It's a AHRI Standad 210/240 model M4A330GKC200.
larbec is offline   Reply With Quote
Old 04-11-2013, 08:19 PM   #2
The unit
This is the outside unit
Old 04-11-2013, 08:35 PM   #3
Rewards Points: 446
They "usually" connect to two stranded wires behind the panel right above where the main electrical wires go in. Make absolutely sure you turn off the breaker to the outside unit before opening the panel.... there is 220VAC at about 30amps inside..... you will get seriously hurt if you get across that kind of voltage. There "should" be a wiring diagram inside the panel also showing where those low voltage control wires connect.
If you're not confident with electricity, call a technician out.
Dogs should not be allowed anywhere near outside air conditioning units. They tend to use them as fire hydrants and their urine will destroy the outdoor coil. Oh, and they tend sometimes to chew on wires.
old_squid is offline   Reply With Quote
The Following User Says Thank You to old_squid For This Useful Post:
larbec (04-11-2013)
Old 04-11-2013, 08:45 PM   #4
Thank you! I'm good with electricity. Been in maintenance as a controls / facilities guy. Just did not know where they went. Never worked on residential units.
Old 04-11-2013, 08:55 PM   #5
Rewards Points: 14,004
A simple vinyl lattis fence or some vinyl fencing with a few 4 X 4's would have prevented that.
Keep it back far enough for service.
larbec (04-11-2013)
Old 04-11-2013, 09:23 PM   #6
We've already picked materials up from Lowe's. She just moved in and let her dog out.
Old 04-11-2013, 09:30 PM   #7
I'm Your Huckleberry
Rewards Points: 2,270
turn the breaker to the furnace (inside unit) off first. gas or electric or what kind of heat? I ask because there is a fuse on gas furnaces that protects the control board that might have blown when this happened. It's a simple 3 or 5 amp spade fuse available at any auto parts store. but if it did blow nothing would work as is so it's pretty apparent if it did or did not.
You should ask your daughter.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-11-2013, 09:32 PM   #8
and the big copper line needs to be insulated all the way to the unit.
Thanks.
Old 04-11-2013, 09:33 PM   #9
and it doesn't matter which wire, red or white, connects to the two wires from inside the unit. no order, just 24 volts there and back.
Thanks.
The Following User Says Thank You to Doc Holliday For This Useful Post:
larbec (04-11-2013)
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Neutral Wires Hot Problem rayray221 Electrical 7 09-20-2010 11:20 AM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 02:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
