Dog Pee In An Air Duct?!?!??!?!! - HVAC - DIY Chatroom Home Improvement Forum
Old 03-11-2009, 11:20 AM   #1
Dog pee in an air duct?!?!??!?!!
Ok, so my dog decided to pee in one of the ducts located on the floor. I don't really know much about HVAC. So my question is, how do I clean it? I searched and only found info on how to clean out dust. Could I just pour some sort of liquid cleaner down the same spot were the dog peed? The vent that got peed in is on the main floor, and I can now smell it coming out of one of the vents in the basement. I've turned off my heat just in case. Please help!!!!
subiefan is offline   Reply With Quote
Old 03-11-2009, 01:49 PM   #2
An old Tradesmen
Rewards Points: 7,356
Might want a tech to see where it ran to.
Cleaner in the wrong place can do far more harm then good.
Old 03-11-2009, 02:12 PM   #3
the Musigician
DangerMouse's Avatar
chihuahua? St Bernard? track the wet flow from duct to lowest point. you may find it's pooled in a dip somewhere and may be able to be wet-toweled out from a different approach. how big are the ducts? how accessible? could you remove a section and replace easily? lots of variables, but it can stink for years if you don't fix it.
DM
Old 03-11-2009, 02:18 PM   #4
Yeah, I'll do it myself.
Oh man. I confess I don't have any pointers, but I'm keeping my dachshund away from the floor ducts. Yikes.
mandisaur is offline   Reply With Quote
Old 03-11-2009, 03:42 PM   #5
Kitty Litter! Throw generous quantities in on top, let it sit there for a few days, then vacuum it with a ShopVac.
Works good on oil spills on the driveway also!
Old 03-11-2009, 07:33 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 2,266
Had a job years ago with a sleazy rooming house and the bums used the return duct for a latrine. Gross!! My sheet metal guy had to replace the ducts and was not happy
Old 03-14-2009, 06:24 AM   #7
Subiefan, You may have a bigger issue. Dogs return to the scene of the crime.
If the vent is exposed I would clean it by dismantling, even clen insied the joints with pine sol or a pet odur cleaner, not a spray, I mean scrub it. Then spray with a neutraliser
But I would also try to figure what the dog smelled to attract him to that spot. Scrub the walls, heat vent, carpet or flooring evrywhere around or you will have a repeat offender.
Bets of luck.
Chemist1961 is offline   Reply With Quote
Old 03-14-2009, 12:33 PM   #8
HVAC / Plumbing
Throw the bumb out !! No dogs allowed inside my home .. Except me
kenmac is offline   Reply With Quote
Old 03-14-2009, 12:44 PM   #9
Hvac Pro
yuri's Avatar
"scene of the crime?" Damn, he's a dawg and just markin his territory.
Old 04-27-2009, 07:41 PM   #10
doggy urine smelly vent
Little late ,just joined,but had same problem,bleach n water,they say 1to10,but like a bit stronger,1/4c and fill sprayer w/water,I use all time when accident on floor,soak up,spray wait 10 mins wipe up.Back to vent,I'd spray quite a bit to follow doggie pee,after spraying with this nothing smells again,the problem I had was a rusted vent cover,so will have to watch vent for rusting and replace when have to.This bleach solution works as disinfectent also.Hope this helps you.
limeysylv1 is offline   Reply With Quote
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 09:38 AM
Furnace install in attic - Duct configuration hartkem HVAC 6 11-08-2008 05:46 PM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 08:28 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 03:22 PM
