Does This Wire Need To Go Somewhere? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 01:27 PM   #1
Does this wire need to go somewhere?
This is under my thermostat. The blue wire wasn't connected to anything and the heater constantly runs (blows out cooler air when desired temp is reached and YES, the setting is on "auto") and sometimes makes clicking noises. I'm sorry, I'm a clueless newbie but I thought that just didn't look/act right.
Alexzandra is offline   Reply With Quote
Old 11-30-2011, 01:28 PM   #2
Oops, forgot pic!
Old 11-30-2011, 02:24 PM   #3
Rewards Points: 95
First I would clean up that wiring. You have a lot of opportunities for bare wires to touch each other.
Can you describe your system a little bit?
garya505 is offline   Reply With Quote
Old 11-30-2011, 08:06 PM   #4
Absolutely. Like I said, I'm a complete newbie but what would be helpful for you to know?
Old 12-01-2011, 03:44 AM   #5
An old Tradesmen
Rewards Points: 6,836
How cold is it outside when it blows this cold/cooler air? How long have you lived there? As in is this the first heating season for you in this house?
When is the last time you had your heat pump serviced?
Old 12-01-2011, 10:50 AM   #6
Rewards Points: 95
Is the fan always running? Or is it just for extended times after heating?
Is your aux heat electric or gas/oil?
Based on your pic of the stat wiring, that blue wire could have been attached to the fault indicator (L), second stage cooling (Y2) or common (C), or not attached at all. In any case, I suspect it's not the cause of the cooler air blowing.
Old 12-01-2011, 12:39 PM   #7
I'm in Nashville so today it's about 45. I normally set it to btwn 68-70. I've lived here about two weeks so yes, first heating season in this house.
I had the house inspected before I bought it about a month ago and he said everything was okay but I don't know if he looked at it long enough to notice that it didn't go off. And the clicking noises must not have happened when he was here..either that or he didn't think it was a big deal.
Old 12-01-2011, 12:41 PM   #8
It's not ALWAYS running..but I'd say about 90 or 95% of the time and it's electric.
So you're saying that blue wire may not need to be attached to anything? That's kind of a relief although shouldn't they have put some sort of cap over the end or something???
Old 12-01-2011, 12:55 PM   #9
Rewards Points: 115
looking at how short the stripped end of blue wire is it is possible that just maybe you will find a small piece of bare wire under an empty terminal that that used to belong to the blue wire. also, maybe you can obtain a wiring diagram from the mfg.
pokey is offline   Reply With Quote
Old 12-01-2011, 03:48 PM   #10
An old Tradesmen
Home inspectors do know how to really check a heat pump. Best bet is to have a reliable HVAC company check it.
Old 12-01-2011, 05:32 PM   #11
Grrr was hoping I wouldn't have to spend the $$ but in this case, you're probably right...to save on electric bills and the peace of mind in knowing it works correctly.
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
