Does Whole A/C Unit Need To Be Replaced? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 09:16 AM   #1
Rewards Points: 238
Question
Does whole A/C unit need to be replaced?
I have just joined the forum, in the hopes if any of the expert out there can help a newbie.
I have just bought a house, was built in 2004 with York units:
Coils Model No: HA12248C175B200584
A/C Model No: H1RA042S06D Serial Number: WCNM046520
Heating Unit Model No: P4HUB16N06401B
A/C was working absolutely fine even in hot weather of DC area for about 2 months, then stopped blowing cold air. I went downstairs and saw there was Ice on the incoming pipe, turned the furnace off for about 2 days, then kept the A/C off for about 2-3 days, replaced the filter and turned the system on.
Still air wasn't not coming cold, I have home warranty on the house, called the company and technician came, according to him there is a leak in system and whole indoor and outdoor unit need to be replaced, which will cost me about $1100, but I DO NOT BELIEVE the technician.
My question is, is it possible that system can go bad in 8 years or technician/warranty company guys are trying to rip me off? Please keep in mind, just bought the house so trying to save every penny.
Any help, input or advise would be greatly appreciated.
helpme81 is offline   Reply With Quote
Old 08-23-2012, 10:43 AM   #2
HOTDAWG
I would have a tech do a leak test on your system, and examine the indoor coil.
If the indoor coil is dirty, you will get the same symptoms.
Affordable Comfort, assisting with furnaces Barrie and surrounding area, as well as offering 24 hour furnace repair
Acomfort is offline   Reply With Quote
The Following User Says Thank You to Acomfort For This Useful Post:
plummen (08-23-2012)
Old 08-23-2012, 11:07 AM   #3
Rewards Points: 238
Is it easy to do a leak test? If so, do these home warranty company run the test or no?
Old 08-23-2012, 11:58 AM   #4
HOTDAWG
There's a couple ways to do a leak test that we use, one is to recover the charge and use nitrogen to pressurize the system, watch your guages and use a soap and water solution to see if you can find any visible leaks, the other is to inject a dye that is visible with a black light.
Whether or not your warranty program covers it, I'm not sure
Old 08-23-2012, 12:03 PM   #5
Rewards Points: 238
Thanks for your response, being a newbie, are these tests so complex that warranty company guys are replacing the whole system?
Any ball park idea about the price, if I hire someone independently to run these tests?
Thanks again for your help.
Old 08-23-2012, 12:46 PM   #6
Electronic leak detectors can find most quickly. Every service person should have one on the truck.
Old 08-23-2012, 01:20 PM   #7
HOTDAWG
I think you should start by having someone come by for a standard service call rate and put some guages on your unit. That will tell you whether its freon or a dirty coil.
Old 08-23-2012, 07:30 PM   #8
Rewards Points: 238
Question
Thanks again, any ball park idea how much it would cost if someone try to find or diagnose the leak?
Old 08-23-2012, 07:38 PM   #9
Rewards Points: 238
I checked with one of the tech today, there is no freon in the system.
By carefully looking around the system, back in 08, there was about 4lbs of Freon pumped into the system by previous owners. Coils were not that dirty, also there was no oil on them.
But according to tech, it's hard to find a leak, he can replace the coils and pump freon in it, but cost he quoted me was more than the one insurance company is asking for the whole new system.
Any thoughts? I am feeling completely in a dump right now
Also, I am in VA, are there any emergency cut off & drain, disposal, disconnect, snow legs, condenser pad, recovery and flush associated charges?
Thanks again guys!
Old 08-24-2012, 01:36 AM   #10
Rewards Points: 616
Thanks again guys!
my goodness ....find the leak and get on with it....its not that hard.....
carmon is offline   Reply With Quote
Old 08-24-2012, 04:43 AM   #11
An old Tradesmen
Rewards Points: 8,154
The Home Warranty company isn't trying to "rip" you off. They are the ones providing the new equipment, and paying the contractor X $ labor to change it out. Usually not near what the contractor needs to do the change out.
The $1100.00 dollars you are paying is for the extras your contract doesn't cover. You are getting a deal. Since a new unit installed by a contractor out of your pocket would be 3 or more times as much.
8 years isn't old for an A/C.
How much a company charges for a leak search is up to that individual company.
Since you said it now has no refrigerant in it, it shouldn't be too hard to find the leak. as you make it sound like a fairly large leak. But replacement of the indoor coil won't be cheap. Since along with it a new filter drier, and probably 10 plus pounds of expensive R22 will be needed. An easy 1200 to 1300 dollars for coil replacement, plus leak search charges.
If you have a contractor replace the indoor coil on your own. The warranty company generally won't cover it for any problems for 1 year. As that is the labor warranty the installing contractor is to provide.
Old 08-24-2012, 05:52 AM   #12
Rewards Points: 1,216
Second opinions cost money but I say you need to have another Company come check it out.
COLDIRON is offline   Reply With Quote
Old 08-24-2012, 08:02 AM   #13
Rewards Points: 108
you are being ripped off that is what those warranty service guys do to make money and help the warranty companies.
Would never use them or trust them without second. I am a home owner.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 08-24-2012, 03:50 PM   #14
An old Tradesmen
I didn't say he was being ripped off.
He's getting a deal at only $1100.00
Old 08-24-2012, 03:59 PM   #15
Rewards Points: 108
Yeah my bad, I have only known 2 folks who have ever goten anything repaired from these types of warranties.
Others are always upsold.
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 10:45 AM
Can I upgrade the compressor in my RV roof AC unit? eoptrab HVAC 10 09-02-2010 04:43 PM
Evaporator unit is out under the house randyloy HVAC 1 08-29-2010 05:33 PM
Deck Landing and A/C Unit Master Brian HVAC 10 07-22-2010 07:08 PM
