Does A Water To Air Coil Cost More Than A Regular Coil? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-22-2009, 03:36 PM   #1
Rewards Points: 184
Does a water to air coil cost more than a regular coil?
If so about how much on the average?
$100 more? $500? 20% more?
Note: This is not a price request for a coil, or a quote request to do the job.
abefroman is offline   Reply With Quote
Old 09-22-2009, 04:22 PM   #2
GetYourShineBox's Avatar
havent you already posted this?
GetYourShineBox is offline   Reply With Quote
Old 09-22-2009, 04:25 PM   #3
Rewards Points: 184
No, not that particular question.
Old 09-22-2009, 04:27 PM   #4
basically the same just worded differently. lol.
How much should a new water to air coil and blower cost, installed?
Old 09-22-2009, 04:34 PM   #5
Rewards Points: 184
No, I think you may have misread it.
Old 09-22-2009, 04:42 PM   #6
Originally Posted by abefroman View Post
No, I think you need to learn how to read.
ok well, the first time you asked how much one costs and now you ask if one is more expensive than a regular coil. to answer your question, yes they are more expensive.
Old 09-22-2009, 04:47 PM   #7
Rewards Points: 184
Thanks, appreciated!
About how much more? Are we talking like double, or like only a couple hundred more?
Old 09-22-2009, 04:50 PM   #8
I guess that would depend on your btu's
Old 09-22-2009, 04:59 PM   #9
Rewards Points: 184
Lets say for 36,000 BTUs
Old 09-22-2009, 05:11 PM   #10
Rewards Points: 184
Do they water to air coils need a higher BTU to cool the same area?
Old 09-22-2009, 06:07 PM   #11
An old Tradesmen
Rewards Points: 6,470
Depends on brand. And distributor, and the contractor(if having it installed).
As contractors. We get better prices then you do. So we can't tell you how much more you will be charged.
Old 09-22-2009, 06:10 PM   #12
An old Tradesmen
The cool is sized to the BTU of the area it will serve. At the water temp it will be supplied with. At the GPM of the water flow that will be available to be pumped through it.
Do you know any of this?
Old 09-22-2009, 06:14 PM   #13
Rewards Points: 184
Nope, it comes from a main cooling tower on the roof.
Old 09-22-2009, 06:15 PM   #14
Rewards Points: 184
You have like a standard mark up though right?
At the contractor pricing what are you, ballpark, looking at? $200 more? $400 more? $800 more?
Old 09-22-2009, 06:18 PM   #15
An old Tradesmen
I don't reveal my pricing.
A contractor that does a higher volume then me, gets a better price.
And I get a better price then contractors that do a lower volume then me.
It is not as cut and dry as you think.
Hot water coil troubles itscoldinhere HVAC 4 02-21-2009 05:36 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Hot Water Heating System Estimate Cost ? helpless handyman HVAC 45 12-26-2006 10:59 AM
