Does The Size Of The Blower Motor Matter? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 09:48 PM   #1
Does the size of the Blower Motor matter?
We were recently informed the bearings in our current motor of the upstairs AC have messed up and this is why the blower fan is not working. The handy man we hired then brought in another motor, but told us after he had already started working that the motor he brought us is 1/2 HP. The original was 3/4 HP. According to him the difference in HP was negligible and we would not notice any difference in how the AC unit cooled the house, nor how fast, how well, and said that this motor would last as long or longer then the original. The Originals was an Emmerson 3/4 HP motor unit with 3.8 AMPS, 1075 RPM, 60 Hz. and 3 speed.
The new was AO Smith MasterFit 1/2 HP motor with 3.9 AMPS, 1075 RPM, 60 Hz. and 4 Speed.
Was the handyman correct?
Or were we correct in canceling the job and looking for another 3/4 HP motor?
Moiz2012 is offline   Reply With Quote
Old 10-25-2012, 10:25 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
you can increase horsepower, to an extent; you can not decrease horsepower.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-25-2012, 10:34 PM   #3
Rewards Points: 29
It isn't only a question of air movement for the motor. It's also a question of load on the motor turning the fan blades, size and weight of the squirrel cage assembly.
A properly sized replacement motor runs $150-$200, at least around here. Replacement isn't that difficult. I suggest you get the motor sized for your unit.
MarkusAIC is offline   Reply With Quote
The Following User Says Thank You to MarkusAIC For This Useful Post:
how (10-25-2012)
Old 10-26-2012, 05:40 AM   #4
An old Tradesmen
Rewards Points: 6,068
By the amp rating of the 1/2 HP you would be ok. Myself, I wouldn't use it in place of your 3/4 HP though.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (10-26-2012)
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Polaris Water Heater Blower TMcCrea HVAC 0 06-10-2012 07:17 AM
Acceptable Blower Vibration John_NH HVAC 15 11-21-2010 01:49 PM
Furnace will not stay on allenzachary HVAC 32 09-21-2010 09:30 PM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 05:48 AM
