Does Sealing Gap Under Bathroom Door Impede Operation Of Bath Vent Fan? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-01-2013, 01:37 AM   #1
Rewards Points: 366
does sealing gap under bathroom door impede operation of bath vent fan?
I don't know much about vent fan operation. My family doesn't like the cold draft air that gets pulled into the bathroom from under the door when bath vent fan is running. If I seal the gap under the door w/ weatherstripping or the stuff you use to block air flow under doors, will that impede the vent fan operation? Does the vent fan need to pull air from outside the bathroom or what's in the room itself is good enough?
daluu is offline   Reply With Quote
Old 05-01-2013, 04:16 AM   #2
An old Tradesmen
Rewards Points: 7,278
It need to pull air into the bathroom. Or else the fan can't do anything. Leave the gap.
Old 05-01-2013, 05:51 AM   #3
Rewards Points: 582
yes if its taking air out ..it has to bring it back in some where....leave gap under door ben sr
Old 05-01-2013, 06:32 AM   #4
Rewards Points: 1,232
So the chilly air being drawn in at the lower level doesn't feel good on the damp feeties eh. You could solve the problem by installing a louver near the top of the door for air admittance and sealing the bottom. That cooler air entering at the upper level would be mixed with the warm humid air as it falls to floor level and never be noticed.
Old 05-01-2013, 09:55 PM   #5
Rewards Points: 950
Be careful about sealing that room up too tight.
The fan could suck some toothbrushes, washclothes, etc. up and out of the room.
Worst case scenario would be the tile being sucked off the walls, then the walls imploding on each other.
Don't risk it man.
cleveman is offline   Reply With Quote
The Following 2 Users Say Thank You to cleveman For This Useful Post:
operagost (05-02-2013), r0ckstarr (05-01-2013)
Old 05-01-2013, 10:19 PM   #6
r0ckstarr's Avatar
Rewards Points: 2,052
Don't risk it man.
That's how black holes are formed.
r0ckstarr is offline   Reply With Quote
Old 05-02-2013, 01:12 PM   #7
Rewards Points: 590
Congratulations, your bathroom fan is working as intended! You could install a fan with a heater element.
operagost is offline   Reply With Quote
Invasion of the Birds - Bathroom Vent tev9999 HVAC 0 10-31-2012 09:53 PM
Birds bathroom vent mess Wheats General DIY Discussions 0 11-28-2010 08:04 AM
Bath fan vent stays open? joe from clev Remodeling 3 06-23-2010 11:08 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
