Old 01-08-2009, 10:02 AM   #1
Does return duct width matter?
I have a return duct for my furnace (cold air return) and also for my air conditioner that is about 5' wide, with openings that are about 18" wide. I am tempted to reduce the width of this vent to accommodate electrical wiring. Does the width of the actual vent matter, or only the width of the openings?
bvbellomo is offline   Reply With Quote
Old 01-08-2009, 10:39 AM   #2
If you are thinking of changing just a straight section of return you need to be concerned with cross-sectional area and the duct material. Changing either could affect the performance of your system.
dac122 is offline   Reply With Quote
Old 01-08-2009, 12:45 PM   #3
An old Tradesmen
Post pic.
Old 01-08-2009, 12:52 PM   #4
I will try to post a diagram when I have time, but cannot post a photo (this is inside a wall)
This is a straight section. Intuitively, airflow is limited by the narrowest cross-sectional of the entire vent. So slightly reducing the cross-sectional area of the vent where it is substantially wider than this should have no effect. However I don't know anything about HVAC so I thought I'd post.
Old 01-08-2009, 03:02 PM   #5
hvaclover's Avatar
Oh great. Another Picasso diagram coming our way ...digital pic is much easier to read.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 01-08-2009, 03:13 PM   #6
hvaclover's Avatar
Don't end up like most DIY projects like this
Old 01-08-2009, 07:36 PM   #7
Um, wow! No words that are suitable for this forum to explain that
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-09-2009, 09:50 AM   #8
Your semantics make it very hard to understand what you are describing.
You seem to use the word "vent" and "duct" interchangably, then also use "vent" and "opening" to describe the same thing in another post.
Furthermore your logic regarding the cross sectional area leaves out a very important piece of the puzzle - airflow. If piece of duct A has more cross sectional area then piece of duct B, it's probably because piece of duct A has more air flowing thru it. So you can't just reduce the cross sectional area of duct A based on the logic duct B is smaller...
Garasaki is offline   Reply With Quote
Old 01-09-2009, 04:29 PM   #9
Home Air Direct's Avatar
I wish I could have sold the flex on that job
I am a big fan of DIY, but that is NUTS
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 01-09-2009, 04:44 PM   #10
JohnH1's Avatar
Boy Isnt that a job to be proud of. I think I just puked a little.
JohnH1 is offline   Reply With Quote
Old 01-09-2009, 05:31 PM   #11
hvaclover's Avatar
I think because we pros have seen so many jobs like that is the main reason we get a bug up our asses when a DIYer says he is going to install a furnace him self.
Then it is up to us to explain to the next HO that the job has to be ripped out and why it cost so much to fix it. Of course that makes us the bad guys then.
That is one reason I am trying to help out here. The biggest concern I have is some poor guy thinking he can just grad a used furnace from someplace and gas it up and put the electricity to and he thinks he's good to go.
Used furnaces are an accident waiting to happen if they aren't safety checked by a knowledgeable person.
Safety first always.
Old 01-10-2009, 09:35 AM   #12
+1 for Picasso. hvaclover, I gotta tell ya, I have laughed for the last two days over your post
My customers are all over the country and there is not a week goes by that I don't hear "I will draw a picture of it and fax it to you" It rarely turns out well. When i saw your Picasso I burst
Jay
Old 01-10-2009, 11:14 AM   #13
hvaclover's Avatar
I agree.
Old 01-11-2009, 03:03 PM   #14
tk03's Avatar
I am a boiler guy. What's wrong with that picture?
tk03 is offline   Reply With Quote
What is the best/easiest way to duct this return air? twilightcall HVAC 10 08-21-2008 11:29 AM
Water in (and around) return duct kennelm HVAC 6 06-18-2008 07:13 AM
Should I seal return air duct? phareous HVAC 1 11-13-2007 12:14 AM
