Does Office Room Require Heat? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 01:28 PM   #1
Does office room require heat?
I'm finishing off an office room in my house. It currently has no duct for heat.. Does an office require this? If so, I will install electric heater.
jclee is offline   Reply With Quote
Old 07-14-2013, 02:01 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,440
depends where U live and whether the room will get cold. I use a oil filled electric radiator style heater for mine. 100% quiet.
Old 07-14-2013, 02:06 PM   #3
No. Offices do not require heat.
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
oh'mike (07-14-2013)
Old 07-14-2013, 02:16 PM   #4
I live in Minnesota
Old 07-14-2013, 02:34 PM   #5
Rewards Points: 6,652
Depends on how you feel in that room. Personally I would do some kind of hvac system in place, to move air, so that room does not get too stuffy, or even worse mold or mildew forms, from too high of humidity, or dry rot from too cold in winter.
Old 07-14-2013, 02:36 PM   #6
I live in Minnesota
No different than living anywhere else in North America. Still gets warm in the Summer and Cold in the Winter.
Old 07-14-2013, 07:22 PM   #7
biggles's Avatar
electric heat run on a perimeter wall maybe catch a return with some flex to move air how much exterior wall space is there..
Old 07-14-2013, 07:34 PM   #8
MarginallyQualified
Rewards Points: 2,464
I'm pretty sure that (an inspector will tell you that) any finished space must be provided with heat and in many places AC too.
What you say (or even what a pretty drawing might say) that the room is intended for really won't matter much.
Old 07-14-2013, 08:46 PM   #9
Rewards Points: 1,016
Heating, yes. A/C, maybe.
____________
Vince
Old 07-15-2013, 08:14 PM   #10
An old Tradesmen
Rewards Points: 6,544
Did that room get cold before you turned it into an office. If so, then it will need heat.
Old 07-15-2013, 08:50 PM   #11
raylo32's Avatar
Rewards Points: 1,240
Did you break up a bigger room to make the office and leave the hvac duct in the other space?
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 07-15-2013, 08:59 PM   #12
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Actually, A great question... With regard to code... I don't really know where to search that one out. IRC has ventilation requirements and egress/window door requirements, and I'm sure some code techncian has legislated a minimum heating heating requirement... but I don't know where to look quickly.
Would you not want heat?
Best
MTN REMODEL LLC is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Isolated Room in Basement - Theater Room EricWindow HVAC 8 11-24-2012 04:19 PM
heat in a patio room psnoopydog HVAC 1 01-18-2011 06:57 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Using server room heat as additional house heat Red Squirrel HVAC 6 10-11-2009 02:35 PM
