Old 01-13-2012, 12:16 PM   #1
Does a new ac system need to be charged?
Hello, I bought a new rheem ac system 1 wk ago and I'm using it for the first time and it's not cooling, my ? is does the system come charged from the factory or does the installer have to charge it? Thanks in advance.
jinxed is offline   Reply With Quote
Old 01-13-2012, 12:22 PM   #2
Disabled wood vet
titanoman's Avatar
It should be fully charged.
Sent from a Samsung Galaxy SII
titanoman is offline   Reply With Quote
Old 01-13-2012, 12:31 PM   #3
REP
Charge should come in the condensor.Installer has to evacuate the line set and evap coil before opening the valves to let the charge fill in the vacuum.It then needs to be checked to make sure it is not undercharged or overcharged.
REP is offline   Reply With Quote
Old 01-13-2012, 02:52 PM   #4
Grognard
andrew4096's Avatar
Originally Posted by jinxed View Post
... does the system come charged from the factory or does the installer have to charge it?
Most home air conditioning system components are pre-charged at the factory -- the condenser, evaporator coils and insulated refrigerant lines. Metal membranes seal the openings and the act of screwing the lines onto the condenser or evaporator pierces the membranes and allows refrigerant to flow. However, if one doesn't mate the parts properly, it is possible to have the refrigerant leak away, requiring a recharge. Installers typically check the pressures with an HVAC manifold gauge set right after the system is assembled and add refrigerant as needed. They also perform leak tests to make sure all the joints are tight.
andrew4096 is offline   Reply With Quote
Old 01-13-2012, 04:41 PM   #5
Depends on what you bought. A new 410A AC will come with charge,a dry shipped R22 AC would not.
Old 01-13-2012, 07:29 PM   #6
vac out line set and open up service valves on condenser?????? who installed it????....
Old 01-13-2012, 08:26 PM   #7
I'm Your Huckleberry
This.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-13-2012, 11:33 PM   #8
Houston204's Avatar
Is this a package unit or a split system?
Houston204 is offline   Reply With Quote
Old 01-14-2012, 04:49 PM   #9
We had a new system (2 years ago) and the cooling was not very effective. We had the HVAC installer out and they told me this particular unit comes precharged with a enough refrigerant for a 10' run, but ours was 20'. He charged it up and it worked perfect
Check out my Man Blog
jasonreck71 is offline   Reply With Quote
Old 01-15-2012, 07:59 AM   #10
jinxed, jinxed, jinxed, Did you read every sentence of the paperwork that was shipped with the unit? If not you should have.
COLDIRON is offline   Reply With Quote
Open Hydronic Heating System... how / need to bleed? MtnMan7 HVAC 1 11-19-2010 04:51 PM
beware humidity system? Emaderton3 HVAC 5 02-11-2010 12:52 AM
Replace/repair decision on 13 yr system pumpkin5 HVAC 13 07-02-2009 09:01 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
