Does This Exist? Thermostat System That Links A/c & Heat Wirelessly? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 08:29 AM   #1
Does this exist? Thermostat system that links a/c & heat wirelessly?
My home has central air and radiator heat, but the thermostats are currently on different floors. I am thinking about updating them to programmable units, but don't know much of anything about thermostats. What I was hoping was that I could buy units that could talk to one another so that I could adjust the a/c downstairs and vice-versa. Is that possible?
aengblom is offline   Reply With Quote
Old 08-27-2012, 06:27 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
how far apart are the boiler and the air handler? If it is feasible you can run wire from the boiler to the ahu and then use 1 stat, but you wont be able to use both up and downstairs at the same time.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-27-2012, 07:37 PM   #3
An old Tradesmen
Rewards Points: 6,480
Get a wireless stat. And take it to the floor you want as the seasons change. Will still need to get the A/C and heat wires to the EIM.
Old 08-27-2012, 09:32 PM   #4
Rewards Points: 6,652
Yes, there are plenty of units out there that allow remote control through either a web interface or smartphone application. Also some use a remote unit that allows you to control the master unit wired in another room in the house.
A few out there are the Ecobee, Honeywell, 3m Filtrete, Nest, Proliphix, and a few others. Depends on what you want, how you want to do it, and how much you want to spend to do it.
New Boiler System Control with 2 stage Heat Thermostat hartkem HVAC 25 07-25-2012 11:56 PM
Heat or Air won't turn off from Thermostat tdsilk HVAC 38 03-06-2012 04:06 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 06:38 AM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
FAULTY THERMOSTAT!!! What the He.... Krazecon HVAC 11 02-12-2009 05:26 AM
