Do You Guys See A Problem With DIY Installin' A Trade Termastat? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 06:20 AM   #1
Seasoned DIYer
Rewards Points: 150
Do you guys see a problem with DIY installin' a trade termastat?
Do you guys see a problem with DIY installin' a trade thermastat?
It's factory configured to work fine for the common single stage heat/cool/fan system and of course you're not going to understand what "220" means unless you read the manual or you have specific knowledge of the product from experience, but other than that, its not really a "pro install" material.
It's only a means of product differentiation and a way for contractors to make $$$. Vision 8000 Pro TH8110 single stage can be had for <$100, but you're going to spend over $300 to have a "pro install".
HVAC_NW is offline   Reply With Quote
Old 10-07-2010, 06:47 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
No problem there. Its when guys with no Pro experience start workin with the gas line or critical safety components that I have a major concern.
Carpenter Ant Problem justinfrompa Pest Control 6 07-20-2009 10:37 PM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 12:00 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 07:10 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
