Do They Make A Programmable Stat You Can Use With Zone Valves? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 07:48 AM   #1
Do they make a programmable stat you can use with zone valves?
my contractor said you need a three wire stat to be used with zone valves. Do they make a programmable 3 wire stat that can be used with zone valves? I need a model with a security code. When I asked him he said he'd have to find out.
h82diet is offline   Reply With Quote
Old 11-18-2011, 08:42 AM   #2
Rewards Points: 348
I have a programmable stat with a zone valve using two wires. Not sure what he is talking about.... On my system the thermostat merely makes the call for heat, it is up to the controller to open the zone valve.
Others here will know a lot more than me though!
dougp23 is online now   Reply With Quote
Old 11-19-2011, 05:02 AM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Honeywell Focus Pro TH6110D can be set up for series 20 operation (power to open and close zone valves)(3 wire operation)
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
any company make a DIAL stat with a 70F max? h82diet HVAC 15 11-02-2011 06:19 PM
What would happen if I make a 5 zone boiler into a one zone? Need advice h82diet HVAC 9 10-17-2011 09:36 PM
Programmable Relay Controller for Solenoid Valves aberrant Electrical 0 01-06-2011 03:41 PM
One Pipe Steam Heat ? II Weeks HVAC 8 03-06-2010 07:54 AM
Boiler - Zone Valves Stuck Open djburns HVAC 3 01-12-2009 11:00 PM
