-   -   do these work ok ? (http://www.diychatroom.com/f17/do-these-work-ok-163823/)
Fix'n it 11-18-2012 10:06 AM
do these work ok ?
my master bedroom currently has no heat duct in it. and the room still stays warm.
in the basement, there is a 6" duct that runs under this bedroom. it is for the front bedroom. i was thinking of putting a (idk what is is called = you cut a hole in the 6" duct. then place this part that is 1/2 of a 6" pipe, that has another duct/hole that goes 90deg) on the 6" duct for the master BR. seeing as how i don't need "full" flow, would this part work ok ?
i think so, but i am asking anyway.
btw, i googled to find what this part is called = nothing.
Fix'n it 11-18-2012 10:15 AM
this is it, a saddle take off.
http://www.homedepot.com/Building-Ma...1#.UKkJioc71hE
yuri 11-18-2012 10:21 AM
That is a 8" pipe unit. You will be robbing heat from the front bedroom and may not be happy with either room after that so I would not recommend it. Better to run a pipe from the main duct or if it was me and your electric rates are reasonable just buy a oil filled radiator heater from HDepot and use it to supplement your room.
Fix'n it 11-18-2012 10:29 AM
yeah, i know that is an 8" = i didn't want to search for the 6".
running the master br on its own duct = i would not be able to put the boot where it needs to go. as the other duct is already there. that is why i want to tap into what is there already. i believe that this duct flows enough air to supply both rooms. and i can adjust the vents to balance it out.
Fix'n it 11-18-2012 10:33 AM
1 Attachment(s)
this is where the vent needs to go. from below.
beenthere 11-18-2012 11:04 AM
Is the bedroom that it already goes to over heating? If not, then it probably doesn't flow enough to do both rooms.
yuri 11-18-2012 11:11 AM
Yep, the velocity in both rooms will drop drastically and you may not be happy with either or get enough flow.
Fix'n it 11-18-2012 11:26 AM
bedroom 2 does not over heat. but it is heating 2 rooms = the living room does not have a register yet.
Fix'n it 11-26-2012 11:19 AM
i put the saddle take off in. it works just as i expected = most of the heated air goes right on past this take off. very little comes up. though, i will say that i didn't cut a clean 6" hole in the main duct = i made a square 4"x4" hole = angle grinder. as it turns out, how i cut the whole, there was some metal that i just pushed down into the airflow. both rooms now have enough heat.
