Do These Fins Look Dirty? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-08-2014, 08:35 AM   #1
Rewards Points: 12
Do these fins look dirty?
I just had one of the AC companies come through and do a check up on the AC. He cleaned the fins on the unit outside but didn't clean the fins on the unit inside.
Does this look like it needed to be cleaned?
(attached since I don't have 5 posts yet to post a linked pic)
How do I go about cleaning these? Can I use an air compressor?
They didn't leave much room at the bottom for drainage so I don't think I can use a hose without making a mess.
Thanks in advance
Do these fins look dirty?-p1420295.jpg   Do these fins look dirty?-p1420296.jpg
foolios is offline   Reply With Quote
Old 07-08-2014, 09:01 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 92
Does not look too bad. You can spray it with citrus based cleaner like Simple Green and then flush it well with water. The issue is whether the coil is dirty underneath as that is where the air and dirt enters. If you can get under it by cutting a hole in the sheetmetal then it can be checked. Sometimes that is not possible and we drill a hole and use a inspection camera/bore scope.
I can tell if the unit is working properly by the Freon pressures and temps so you may have nothing to worry about.
The Following 2 Users Say Thank You to yuri For This Useful Post:
foolios (07-08-2014), plummen (07-26-2014)
Old 07-08-2014, 09:19 AM   #3
HVAC TECH.
KKinnaman's Avatar
Those fins do not look bad however, I don't know if I am looking at a coil in the upflow or downflow position. If it is downflow they look fairly clean, but if it is upflow you are not looking at the side of the coil that would be dirty. You would need to remove the front cover of the A-coil to gain access to the air inlet side of the coil, that is where you would find the dirt build up.
KKinnaman is offline   Reply With Quote
The Following User Says Thank You to KKinnaman For This Useful Post:
foolios (07-10-2014)
Old 07-08-2014, 09:56 PM   #4
An old Tradesmen
Rewards Points: 7,730
If thats an upflow coil, its pretty dirty. And if its a down flow its time for a cleaning.
http://www.zoro.com/g/00034105/k-G05...BrzBoCAtrw_wcB
http://www.zoro.com/g/00034105/k-G17...mhGxoCTvjw_wcB
Either of the above to clean it.
The Following User Says Thank You to beenthere For This Useful Post:
Old 07-10-2014, 06:33 PM   #5
Rewards Points: 12
I believe the intake air flow is coming downwards from above. That's where there is two pipes coming from registers that are sucking in air.
Thanks all for the advice.
Old 07-12-2014, 04:26 AM   #6
I'm Your Huckleberry
Rewards Points: 2,270
Grief, Bt..
Thanks.
Doc Holliday is offline   Reply With Quote
Old 07-26-2014, 09:27 PM   #7
Rewards Points: 12
Well, it's been two weeks since I ordered that spray from that link. That zoro website hasn't taken my paypal payment and aren't responding to my order.
Really weird. I've never had paypal funds just sit there during a transaction before.
Well, I found this at Home Depot:
http://www.homedepot.com/p/AC-Safe-A...-920/100599017
and am going to give that a try.
Old 07-27-2014, 04:29 AM   #8
An old Tradesmen
That should work.
Old 07-28-2014, 07:02 AM   #9
Well wanted to know how whether you succeed attempt for home depot, because I am planning to get repair service from <Link not needed> as suggested by my friend. So would like to know your review to make decision!
jarrellmary4 is offline   Reply With Quote
Help -Dirty Well Water After Pump Replacement msquared100 Plumbing 4 05-27-2014 06:39 PM
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
Cleaning Baseboard Hotwater Fins RCrosby257 General DIY Discussions 6 07-18-2011 04:05 PM
Painting dirty walls SimpleJack Painting 27 02-20-2010 07:51 AM
Stucco Fins vs. Nail Fins on Stucco House xquercus General DIY Discussions 5 01-25-2009 04:44 PM
