Do Older A/C Need TX Valves? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-13-2010, 06:38 PM   #16
My furnace is a Lincoln supreme.
Here is the label picture: http://img43.imagevenue.com/img.php?..._122_408lo.JPG
myleena is offline   Reply With Quote
Old 07-13-2010, 08:24 PM   #17
So... do I need a TX valve or not? I am confused
Old 07-13-2010, 08:24 PM   #18
Hvac Pro
yuri's Avatar
Rewards Points: 1,816
No, order what I described. Where do you live? Is it an oil furnace, you need to read and post the model # for us, too blurry to read.
Old 07-13-2010, 08:28 PM   #19
Hvac Pro
yuri's Avatar
OK, I got it, it is a 20 kw electric furnace. Not sure if it has a powerful enough blower for a 2.5 ton AC unit. How old is the furnace?. You may have to do some research to find out what the manufacturer allows to be used in that furnace for AC. We would also have to see if your ducts are big enough for a 2.5 ton AC. This is why installing used units does not always work out so well.
Old 07-13-2010, 08:36 PM   #20
An old Tradesmen
Rewards Points: 6,870
See post #11.
Old 07-13-2010, 08:38 PM   #21
Hvac Pro
yuri's Avatar
Don't order anything until we know where you live, square footage of your house and from that we may be able to tell you if the unit is too big for the house. If it is then it will freezeup and get ruined.
Old 07-13-2010, 08:46 PM   #22
I am not sure how old the furnace is. I think it was changed from oil to electric in 1996 - about 15 years ago or so.
I live in Montreal, Canada where the winters are VERY cold and the summers, way too humid.
My house is 1300 square foot I believe (+basement).
Please don't tell me I need to buy a new AC...!
Old 07-13-2010, 08:48 PM   #23
New price quote from vendor - They don't have ADP:
Uncased Aspen A Evaporator Coil – 2.5 ton - $220 – with no TX Valve – 13” W x 19 3/8” D x 14” H
Uncased Carrier N Evaporator Coil – 2.5 ton - $290 - with TX Valve – 12 11/16” W x 19 3/8” D x 14 3/8” H
(I told them my furnace was 20" x 20")
Old 07-13-2010, 08:53 PM   #24
An old Tradesmen
New coils are generally designed to fit newer furnaces and air handlers.
Your HVAC guy will have to make the proper transitions to it.
Old 07-13-2010, 08:54 PM   #25
Hvac Pro
yuri's Avatar
You know where I am, got nothing on me when it comes to cold Winters. I highly suspect that you need a 2 ton unit as that is what we would put in in Wpg. I doubt that furnace has a 2.5 or 3 ton blower in it. If you have large old school ductwork you may get away with it. I think you need your friend or someone in the biz locally who understands ductsizing and what that furnace can handle. It will be a huge waste of time and $$ if it is too big as it will freezeup from poor airflow. If you can find the fan specifications from Lincoln or in the owners manual and it is rated for 2.5 tons or 3 tons of AC and your ducts are big enough then your are okay. If not, Sorry.
If it is oversized it will also not run long enough to de-humidify your house. You will get a cold and clammy feel, like walking into the Safeway meat dept. 2.5 ton would be good for 1600sq feet where I am and would be matched to a 25 kw furnace.
Back tomorrow, got a early service meeting and need my beauty rest.
Old 07-13-2010, 09:39 PM   #26
I understand... :-(
My house was built in 1950, so I guess I have old ducts.
What if I am planning to change the whole system to a heat pump in 2 years.. would it be worth it? I would be paying $500 total and think I can handle not being comfortable for the few weeks of hot summer we have up here. It's so hot here I can't stand it and am looking for a quick fix.
And still don't know if I need the TX valve.. I read and re-read post #11 which says "A 65 piston will work. Thats what it says on that label. " but to me, who is not a technician, it means nothing.
Thank you all for taking the time to reply to my newbie questions, it is very appreciated.
Old 07-13-2010, 10:04 PM   #27
An old Tradesmen
Post 11 means, you don't need a TXV. And the label tells the tech what size piston to use.
If its just for 1 or 2 summers. I'd buy 2 cheap window A/Cs. And use them. probably save 200 to 250 bucks over having this unit installed.
Old 07-14-2010, 05:46 PM   #28
Hvac Pro
yuri's Avatar
Beenthere is right. 2) 12,000 BTU window units (which you can resell later) is a better idea. The other option is going to be a lot more than $500 in real world dollars. Unless your friend wants to donate: freon, expensive copper lines and thermostat and high voltage wire and a thermostat, all those items have a dollar value. If he does then you owe him big time.
Stop valves in bathroom while drywalling StevePax Plumbing 11 01-17-2010 05:52 PM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-14-2009 11:17 PM
shutoff valves all leaking hohadcr Plumbing 1 08-01-2009 06:38 AM
why do my 1/4 turn valves leak? moondog111 Plumbing 1 12-07-2008 11:09 PM
shut off valves on cast iron radiators bdw2677 Plumbing 2 10-21-2008 07:07 PM
