Do I Replace Heat Exchanger Or Wait? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 10:56 AM   #16
Originally Posted by hvactech126 View Post
yes, they are unreliable. I have seen brand new out of the box alarms put in a ziploc bad and filled with 100 ppm CO from a can and the alarms NEVER went off. Not after 1 hour, not after2 hours, not after 3 hours. How much CO is safe in your home 0 ppm. The UL lab wont put their approval on them unless they have been dumbed down so they dont go off with low levels of CO. Low levels at sustained periods of exposure can be very harmful.
Where can I get a quality CO DETECTOR? Is this even a reasonable request? What do you have in your home?
coder_t2 is offline   Reply With Quote
Old 12-18-2011, 11:30 AM   #17
AKA HVACTECHFW
Rewards Points: 1,208
I gave you the site already http://coexperts.com
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-18-2011, 01:33 PM   #18
thats probably one of the easiest heat exchangers to change, I have done them in less then 2 hours, many times. why take chances with your life or your family's life......?
harleyrider is offline   Reply With Quote
Leaking Heat Exchanger in Furnace - Heat On Brentimus HVAC 1 03-19-2011 09:42 PM
Rheem Heat Exchanger Noise Vulcanus HVAC 0 12-19-2010 10:42 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
Carrier Heat exchanger ericcolon HVAC 1 01-28-2009 10:44 AM
