Old 07-07-2010, 01:48 PM   #1
aar
do I need to use the infinity thermostat with the infinity system or can I use the edge
We are getting quotes for a new heat pump and furnace. We a looking a the carrier 16 seer performance series heat pump and the 80% or 95% infinity series gas furnace. We have had 5 different quotes and 5 different answers. do I need to use the infinity thermostat with the infinity system or can I use the edge. any help would be appriciated.
aar is offline   Reply With Quote
Old 07-07-2010, 06:02 PM   #2
An old Tradesmen
Don't know why you would get an Infinity system and cripple it with an Edge thermostat.
You can use the Edge. But its not as good as the Infinity.
The Following User Says Thank You to beenthere For This Useful Post:
aar (07-07-2010)
Old 07-07-2010, 06:36 PM   #3
aar
what is the main difference between the edge and infinity thermostats
Old 07-07-2010, 07:42 PM   #4
An old Tradesmen
The Infinity does total communication with the equipment. The Edge does.
The Infinity will adjust/vary blower speed per the indoor conditions. Report errors, and give more control on blower speed for humidity control. Also more blower, and stage control in heating.
aar (07-13-2010)
Thermostat for new heating system pb2 HVAC 0 11-30-2009 12:41 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 11:07 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 04:00 PM
