Do I Need A Power Vent Water Heater? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-20-2011, 04:55 PM   #1
Rewards Points: 14
Do I need a power vent water heater?
I currently have a natural vent gas furnace and water heater, both venting through a b-vent.
If I replace the furnace with a high-efficiency model that vents through the wall, do I also need to replace the water heater with a power vent model?
Or can the water heater continue to vent through the b-vent?
One contractor says no problem, the other did not mention the natural vent as an option.
Price would be 600 more for a power vent Bradford-White heater compared to natural vent.
Thanks.
bw77 is offline   Reply With Quote
Old 06-20-2011, 05:05 PM   #2
Rewards Points: 1,216
No you don't have to replace the water heater all you need to do is cap off the pipe the the heater was vented to or remove the Y and replace it with a single vent opening sized for the water heater flue pipe.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
bw77 (06-21-2011)
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Power vented water heater noise mainstreetprod Plumbing 1 02-06-2009 10:26 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
