Do I Need Dampers? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 11:01 AM   #1
Do i need dampers?
Well my question is basically two fold.
1. I am finishing my basement and adding registers and a return air to the system. I see that the ductwork currently has dampers in the system. I am drywalling the ceiling and curious why dampers are needed? Can't the airflow be adjusted at the registers in each room? Help me understand.
nickm1024cobra is offline   Reply With Quote
Old 02-16-2011, 01:15 PM   #2
Rewards Points: 508
Dampers allows for a system's airflow to be accurately balanced. If it's done at the registers, it makes more noise when not completely open. A damper will too but because it's deeper inside the system, dampened by sheet rock and insulation, it's less noticeable at the register.
diyorpay is offline   Reply With Quote
Old 02-17-2011, 01:44 AM   #3
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
1 out of 20 systems have dampers, I always put them in, its really helpful to be able to balance airflow for a customer, it should always be done if you ask me.
unicursalhex is offline   Reply With Quote
Old 02-17-2011, 04:41 AM   #4
An old Tradesmen
Rewards Points: 7,794
Using the dampers in the registers often causes an annoying air flow noise.
Dry walling a basement ceiling if it has plumbing pipes in it. Is an expensive leaking plumbing repair down the road. A drop ceiling is often better.
range hood, two dampers in cold climate? zantar Appliances 12 04-13-2011 08:19 PM
Duct dampers GimmeShelter HVAC 1 02-02-2011 01:30 AM
geothermal units/ dampers and zones standard? MLMIB HVAC 5 10-24-2010 02:12 PM
AC backdraft dampers? wmmurphy HVAC 6 10-23-2010 05:10 PM
Manual dampers vs. motorized w/smart sensors and zone control... charljlee HVAC 0 06-27-2010 12:05 PM
