Do I Have A Heat Pump? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 12:28 PM   #1
Do I have a heat pump?
This may be a dumb question, but how do I know I have a heat pump?
I recently moved into a house with a central air conditioning system. We weren't told there was a heat pump. However the thermostat has a heat setting. Whenever I turn it to heat, the transformer on the air conditioner immediately burns out.
So, do I have a malfunctioning heat pump or the wrong kind of thermostat Are there any dead give-a-ways?
There are 4 wires coming off the thermostat and going into the unit. The panel on the unit says "Lennox Heater Installed" My house does have an electrical heat, but it is inadequate to heat the house by itself. Last winter I relied primarily on a pellet stove.
The central air system itself is about 20 years old and is due for replacement, although I am hoping to get one more year out of it before I have to drop 10K on a new system.
Thanks for the help
Woodsman is offline   Reply With Quote
Old 08-19-2011, 12:33 PM   #2
fabrk8r
fabrk8r's Avatar
Can you post the model and serial number on the outdoor unit?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-19-2011, 04:03 PM   #3
look into ur outside unit (condenser) and if you have something that looks like this you do have a heat pump system. the transformer burning out is a short somewhere in the circuit.
Final Notice is offline   Reply With Quote
Old 08-19-2011, 04:07 PM   #4
yours will be darker in color though
Old 08-19-2011, 04:21 PM   #5
biggles's Avatar
pop the stat off the subbase tell us what connections other then R,G Y W C....
Old 08-19-2011, 05:45 PM   #6
Twenty years old and only 4 wires at the stat,it's not a heat pump.
Old 08-19-2011, 07:37 PM   #7
I can run a heat pump with 4 wires at the stat..and 3 wires at the condenser...
Master of Cold is offline   Reply With Quote
Old 08-19-2011, 08:09 PM   #8
Cool. Care to share how?
Old 08-19-2011, 09:53 PM   #9
Customer went from a straight cool to a heat pump. Salesman said" no problem". It was a 2nd floor of a 3 floor condo.
Used a battery stat. Hooked up r,g,y,o. At the air handler I hooked up a ranco digital refrigeration controller with orange wire controlling a relay to close the line side of the output of stat, for heatstrip contactor. On at 100, off at 110, for the heatstrips
Outside I had 3 wires. I put in a transformer for the board power and ground. Hooked up y,o,and w. The w was ran to the heatstrip contactor to force it on, without the controller. I also put a toggle switch on the side of the air handler for emergency heat. It would kick on the fan and strips.
The Following User Says Thank You to Master of Cold For This Useful Post:
Marty S. (08-20-2011)
Old 08-19-2011, 11:17 PM   #10
nice.
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 05:51 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 03:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
