Old 10-20-2007, 06:15 PM   #1
Do I have to get a new A/C when replacing a furnace?
I have a 20 year old furnace that I think that I should have replaced before winter hits. My A/C is probably close to 15-20 years old, but I am not sure that I really need to replace that yet. The way I see it, having a funrace go out in the middle of winter is worse than having the A/C go out in the summer.
I have been told that I would save about $300 in labor if I get the A/C unit replaced. I would rather wait until the one I have now breaks before replacing it. One company told me they would not install one without the other, and the other company said that matching the systems would be best, but not required.
I just can't understand why replacement of both is advised, especially since they don't tyically have the same lifespans...
I would appreciate any and all responses.
Thank you.
Kyle is offline   Reply With Quote
Old 10-20-2007, 07:13 PM   #2
catch 22 mate.....if you dont replace the A/C it will break next sumer lol.. always the way....As long as you getting around the 7 - 12 max degrees C air off the coil on around 20 degrees c ambient then thats working o.k m8.
fridgeman is offline   Reply With Quote
Old 10-21-2007, 11:25 AM   #3
There is no hard and fast rule that you have to replace your A/C when you change your furnace. In my experience, in replacing equipment I would say that it is far more common to replace each item individually than both at the same time.
There are some advantages to changing both at once. It allows the installer to match equipment to best meet your needs, as well as allows for making the necessary ductwork provisions for both pieces of equipment at once so that you dont have to try and make the new A/C coil fit later, if your discharge duct is perhaps a bit smaller than your coil footprint.
I suspect you are trying to be sold both units at once so that the company can maximize thier profit line in this instance. They can likely replace both your furnace and your A/C in the same day, instead of doing both separately in 2 different days, tying up an installer for essentially 2 days instead of one. They are trying to lure you in by offering you the $300 savings, which may be an advantage, but if you don't want to spend the cash, then I would risk sticking with your old A/C for now.
If there are other considerations which they are offering, such as higher efficiency units that are drawing less power, then changing the A/C sooner may be a consideration. If this is so, you will want to get some data on the SEER(seasonal energy efficiency rating)of both your old unit as well as the new unit they are selling.All new units are now required to have a SEER rating of at least 13 and your old unit would likely have a rating of 10 which should translate into about a 30% savings in electrical consumption per year for the A/C. You can also purchase higher SEER value equipment than the standard, which will deliver even greater efficiencies, but of course will also have a higher price tag.
Hope this helps,
Dave
HVACDave is offline   Reply With Quote
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
You found the house of your dreams, and all the inspections, mortgage paperwork and contracts are done. It's time for that final walk-through before heading off to the closing. Don't take a final walk-through lightly; it's your last chance to spot... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be changing our furnace filter. Now right before winter I always recommend to people to go ahead and change out their old furnace filter with a new one. On this unit our furnace filter... Read More »
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. This is the furnace and this is the door of the furnace, see these are ceramic tiles, this is fiber and these there is 2 coils inside the furnace. After finishing up the... Read More »
Heil Furnace Burner Problem timothyr HVAC 65 10-26-2009 04:49 PM
replacing old oil furnace with new propane hi eff. What have I done HVAC 1 10-04-2007 07:02 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Replacing Old Boiler Type Furnace bobo HVAC 15 10-29-2006 10:45 AM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 07:10 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
