Do FHW Baseboards "wear Out"? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 12:18 PM   #1
Rewards Points: 348
Do FHW Baseboards "wear out"?
House is about 25 years old. We've had some real cold weather lately, and sometimes with the heat running, the room temperature cannot get above a certain level, no matter how hot the boiler is running. Would it be worthwhile to replace the baseboard heaters? The fins all look good, some mashed here and there - normal usage looks like.
I did vacuum them all, but there wasn't that much dust and stuff in them. Just wondering!
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 01-03-2013, 12:24 PM   #2
Rewards Points: 13,732
How long have you been living in this house?
Old 01-03-2013, 12:36 PM   #3
REP
Not enough info to help you.I.E. how big is the room and how long is the baseboard.Is it normal 3/4 copper or high output 1 inch..Where is the baseboard located.Is it under a window on an outside wall or on an inside wall.Have you put furniture in front of it or do drapes cover it???Has that room ever been heated right???
REP is offline   Reply With Quote
Old 01-03-2013, 12:40 PM   #4
Rewards Points: 590
How hot do they get? There may be air in the system.
operagost is offline   Reply With Quote
Old 01-03-2013, 01:11 PM   #5
Rewards Points: 610
Is the circulating pump running..Is impeller worn? causing less circulation. If there are vents on rads open them to see if any air ..let air purge out until water runs in a smooth stream. May have to add a rad if insufficient heat.
What pressure is system/boiler running at. Normally 12 -15 psig Or up to 20 if three story house.
techpappy is offline   Reply With Quote
Old 01-03-2013, 02:31 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Ayuh,.... The actual baseboard radiation don't wear out,...
Mine are 'bout 40 or 50 years old, 'n still workin' just fine...
I'd look to the boiler, valving, 'n the pumps myself...
Old 01-03-2013, 02:37 PM   #7
Rewards Points: 266
Is the boiler running continuously in that cold weather? If not, what is the water temp?
ionized is offline   Reply With Quote
Old 01-03-2013, 02:44 PM   #8
Roofmaster
Rewards Points: 2,210
Ive never known them to. Check for air lock, and proper pump throughput.
New Carpet over hardwood with existing baseboards denovo Flooring 2 04-23-2012 10:01 AM
Baseboards before or after skimcoat? BagOfMostlyWate Drywall & Plaster 5 10-23-2010 08:43 AM
Should new baseboards go on top of carpet? hawks81 Flooring 4 08-23-2010 11:25 AM
Masking off baseboards 2 PaintedSurface Painting 1 01-18-2010 04:30 AM
Help removing baseboards without damaging sheetrock Lighthearted Painting 3 04-05-2009 05:52 PM
