DIY Seasonal A/C Maintenance - HVAC - DIY Chatroom Home Improvement Forum
Old 05-29-2008, 09:46 AM   #1
Rewards Points: 150
DIY seasonal A/C maintenance
Does anyone have a decent how-to for the DIY'er to perform their own seasonal air conditioner maintenance? I'd like to tackle most of the maintenance work for the A/C just as I did for the furnace last fall (open, inspect, clean out any dust, etc...), but am unsure exactly what to check.
Any advice is appreciated, thanks!
curls00 is offline   Reply With Quote
Old 05-29-2008, 10:38 AM   #2
Registered User
Termite's Avatar
There isn't a heck of a lot you can do without gauges and specialized tools.
One thing that will make a big difference is cleaning the unit's coils. Shut off its power at the breaker or disconnect, remove the cover, and use a gentle hose stream to remove leaves, dirt, and debris from the fins. It will be more efficient if it is clean.
As far as actual servicing and routine maintenance, I'd say you'd better call a pro.
Old 06-05-2008, 08:47 PM   #3
clean everything
ro9beam2002 is offline   Reply With Quote
tile maintenance? joeyboy Flooring 5 05-02-2008 05:34 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 03:09 PM
High-level maintenance schedules? NothingsLevel General DIY Discussions 1 09-04-2006 11:25 PM
Home Maintenance Checklist sherlock General DIY Discussions 2 02-16-2006 07:22 AM
