Old 09-28-2011, 10:56 PM   #1
diy redneck geo thermal system
greetings all,
I am getting ready to build a new shop building...60' x 100'. I have this idea about a diy geothermal system and wondered if any of you had any thoughts on it.
What I am thinking is to bury a 6-8" solid plastic tile about 5-6' deep and circulate air through it to partially heat and cool the shop. I have plenty of room to bury the pipe, and can put in several hundred feet if needed. I planned to use only air to circulate through this and run the air right into the shop. Do any of you know if this will work? The shop will be insulated and I plan to use radiant heaters to supplement this as needed.
I am also considering heat in the concrete floor with water and a water heater instead of or in addition to the geothermal air system.
Any thoughts are appreciated.
1Oldguy is offline   Reply With Quote
Old 09-29-2011, 06:21 AM   #2
raylo32's Avatar
Just a thought for you... I would worry about mold growing in the pipe over time. The air passing through the pipes might pick some up and blow it around inside your building. Could be an irritant, esp for those with allergies and such.
You could probably design a system with an air to air hx to isolate the conditioned air but would be more $$ and you'd need some calcs to see if it is even worth doing.
Originally Posted by 1Oldguy View Post
greetings all,
raylo32 is offline   Reply With Quote
Tags
cooling, geothermal, heating
Open Hydronic Heating System... how / need to bleed? MtnMan7 HVAC 1 11-19-2010 04:51 PM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 04:26 PM
Which heatings system should I go with? keano016 HVAC 5 12-01-2009 03:53 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
