DIY Install Ductless Mini-split System? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-15-2008, 02:16 PM   #16
DIY'r
ScottR's Avatar
It also says they are relatively new to Nort America.
Mini splits have been around here for longer then I can remember.
Yeah, true, but I think they meant the brand was new to NA.. Though how "old" it is to the rest of the world, I don't know. Maybe there are a million satisfied customers overseas? (Kinda doubt it tho.)
ScottR is offline   Reply With Quote
Old 10-15-2008, 02:20 PM   #17
DIY
Rewards Points: 150
Originally Posted by hvaclover View Post
And what you DON"T KNOW can hurt the equip.
Yes I know, that's why I'm asking here.
I do have some basic HVAC knowledge. I'm not starting entirely from scratch here.
gp_wa is offline   Reply With Quote
Old 10-15-2008, 02:27 PM   #18
An old Tradesmen
Rewards Points: 7,278
Ductless/mini splits are quite common in Erurope.
In some countries. Your rent includes X amount of heat. That heat is based on a stat setting of 62F/16.5C. You are then billed at the end of the year for more heat if you turn your stat up.
They pay more for energy then we do. So they don't cool the whole house 24/7.
Old 10-16-2008, 09:35 AM   #19
you can purge the lines on any system. it's not enough. moisture [you bet]=problems. the way they word it is misleading. the whole policy/sales sheet is misleading. if you buy it from ac world you get one year-C'. says 5 ??. they also may ask for hvac guy to check it first for warranty claim. you can bet they'll make you do this. also disclaim any responsibilty for violating EPA laws [big fine] $10,000 reward for turning someone in. these ad's are all over the internet. i'm all for DIY but that's a lot of $$ to take a chance on. there's a reason people go to long schools to learn and continue to learn this trade. you see the video on TOHouse?? SOO easy and then he says we call a pro to do the start up. that's the hard part. anybody can do the basic install.
Jacques is offline   Reply With Quote
Old 12-29-2010, 11:21 AM   #20
Thumbs up
ductless system
I'm getting a ductless split system air conditioner to mainly heat a 480 square foot room. The calculations were done and a 15kBTU system should work fine...actually 12k is OK except with cold outside temps. Winter temperatures range from +15F to +25F. Single digits are uncommon...
Regards
dorothyamazona is offline   Reply With Quote
Old 07-02-2015, 05:35 PM   #21
Rewards Points: 46
14k just for labour, or whole job? Some people won't want to do it, so they quote high so that if you still choose them at least they are will compensated. I couldn't imagine anymore then 4k to be honest for it locally here. Probably less. (labour only, no materials or troublesome issues)
Cheers!
supers05 is offline   Reply With Quote
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 09:33 PM
Ductless split system - advice mikeyd HVAC 9 06-26-2007 05:23 AM
5 Ton split system keeps shutting down mahjohn HVAC 1 06-10-2006 07:31 AM
