DIY HVAC Total Install - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 09-05-2012, 09:34 AM   #46
Rewards Points: 610
we are in a 2500 sqft 2 storey house with only one register in each room with absolutely no issues with temps throughout so, can't see why two registers in your living room...mind you we are north of Lake Ontario and didn't install AC..colsd air is harder to circulate but if you have a return centrally located I think you should br OK
techpappy is offline   Reply With Quote
Old 09-05-2012, 01:58 PM   #47
An old Tradesmen
Rewards Points: 7,408
And your registers are probably on the outside walls. Look at his layout.
Old 09-05-2012, 04:50 PM   #48
Rewards Points: 610
Hi Been There ... I believe his layout was tentative pending comments and if you go back to previous threads I have already advised him to place registers under windows and to move the kitchen one under a cupboard and vent out the front for kitchen supply. However I just noticed his drawing shows register for laundry room in doorway. Hopefully he can move that to inside wall AND move LR to under window as well. He may have restrictions under house to reaching those areas. I hope not. Let's not forget we are talking about a relatively small area so I would think one register should suffice.
Old 09-05-2012, 04:53 PM   #49
An old Tradesmen
275 sq ft.
Old 09-05-2012, 05:04 PM   #50
Rewards Points: 610
same size as my FR. (4" X 12" register)...no problems..however I have never measured actual duct pressures/air flows..everything worked fine from the getgo so not necessary
Old 09-05-2012, 07:13 PM   #51
DIY staff
Rewards Points: 7,174
Just a thought----there are many independent sheet metal shops that make up plenums and odd shaped tin work---
My neighbor had a few special pieces made up when he DIYed a new furnace---didn't cost a lot as I recall.
Old 09-05-2012, 07:17 PM   #52
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
I have notes of your advice, I will add a register under the window in the living room and have one where it shows now. The reason I put the register in the door of the laundry is there just any place else to put it in there, there is a clothes hamper it the right hand corner. Hopefully I can get under the house tomorrow and get some measurements. I really appreciate you guys.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-05-2012, 07:30 PM   #53
Rewards Points: 610
That will work! going away for a few days... back atcha later..good luck with everything..I'm sure there's lots of guys out thetre who will be providing good advice..we all want to see you succeed.. Just do all the grunt work and get a pro to do the refrigerant lines and set up
The Following User Says Thank You to techpappy For This Useful Post:
BigJim (09-06-2012)
Conclusion to: Can I install an HVAC unit myself Madix HVAC 19 03-09-2012 01:32 PM
Can I install an HVAC unit myself? Madix HVAC 40 02-21-2012 02:48 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
What's prevents a good HVAC system install? Yoyizit HVAC 9 04-29-2009 05:03 PM
