DIY Air Duct Cleaning... How To? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-14-2005, 11:35 AM   #1
EspressoMan
DIY Air Duct Cleaning... How to?
I have a small house that I bought two years ago. It has forced air heat and i added central air. The duct work was installed in 1997 and I seriously doubt that it has ever been cleaned. I cleaned the air intake duct work already. it was easy to access and with a mop, a shop vac and a rag i got a lot of dust out. About 1/2 inch of dust film had accumulated on the walls of the intake duct.
How can I clean the heating/cooling ducts? They are 4 1/2 inch solid galvanized steel pipe with collar connectors and they have 90 deg. elbows as they go from the basement thru the walls. Any suggestions? Would a light duty roto-rooter type snake cable with a car wash sized sponge on the end work? I don't think any of the ducts are over 40 ft. long so a light weight roto-rooter type snake with a rag or sponge on the end might do it? Would the roto-rooter snake tear up the duct work? Any advice is appreaciated. :confused:
singforsupper is offline   Reply With Quote
Old 06-25-2005, 02:02 AM   #2
dont bother unless you have a moisture problem .the dust that is in there is clinging and not going anywhere ,these duct cleaning guys just clean out the dust that is clinging creating a new spot for dust to settle.though I do agree its someone elses dust yuck...but its not going anywhere .besides ,theres no air moving through a 4" solid galv pipe:D
murray is offline   Reply With Quote
Old 09-18-2005, 06:13 PM   #3
I considered a duct cleaning when I replaced my furnace a few years back. Granted... I was talking to a furnace guy at the time, but he recommended (since I was adding a hefty filtration accessory to the system) that I not bother. Let the filter on the return do the work instead of a cleaning.
raycyrx is offline   Reply With Quote
Old 09-19-2005, 11:10 AM   #4
Why not try to take a section apart and see what is in there if it is accessable. I agree that scratching up the galv. finish would probably make more dust cling to it. I once disassembled all the ducts on a small, 80 yr old house and cleaned them with a soft brush and hose in the back yard. They were not as dirty as I was expecting and much less dirty than the returns and near the floor registers. HS.
K2eoj is offline   Reply With Quote
Old 10-09-2008, 11:02 AM   #5
Enormous Member
skipjack's Avatar
Rewards Points: 87
I just had my ducts done when I had a new furnace put in. I'm sure they hadn't been cleaned in 50 years. I was watching the guys and they hooked a big flexible tube to a vacuum in their truck. This put negative pressure in the system and then one guy went around with what looked like a long, rubber cat o' nine tails attached to a crank and this thing would essentially thrash around in the ductwork loosening up all the gorp while the vacuum sucked it out into the truck.
It was a pretty dirty job, in my case. But it only cost a couple hundred bucks to have someone do it.
Your ducts were installed in '97... unless there's a lot of pet hair flying around, I'd say your ducts are probably not that bad.
skipjack is offline   Reply With Quote
Old 10-09-2008, 01:06 PM   #6
I live in an area with identical heating/cooling seasons as you. I just opened my plenum while doing work on my furnace and got a good look down my 27' 20 year old trunk. The fine layer of dust I saw is not worth a few hundred bucks to maybe get it and all my runs clean. If you have a major mold problem I might consider it, but then you probably have bigger problems than that.
I would save your money and just replace your filter every 30 days during heating season like most people don't.
dac122 is offline   Reply With Quote
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 04:22 PM
Can I use duct tape? Dusty HVAC 2 09-27-2006 09:28 PM
Air Duct Cleaning Machine BigC General DIY Discussions 1 07-29-2006 09:15 PM
duct cleaning mcgina HVAC 2 07-10-2006 07:29 PM
