Distance From Compressor To Air Handler?? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2008, 03:59 PM   #1
Cool
Distance from Compressor to air handler??
Hello all just a quick question about heat pumps and distances. I want to put my heat pump around the far side of my house and run the lines outside and then into the furnace room. My question is what is the max run for a 3ton heat pump. Most of them come with 15' lines but I have seen 30' and 50' lengths for sale. Is there anything wrong with this idea?
freefly6 is offline   Reply With Quote
Old 09-06-2008, 06:07 PM   #2
oops, did I do that!
In the IOM, or Instalation Operation Manual, there should be a chart that cross references the distance and size the line set should be, and the maximun recomended distance. Sure you can put it wherever you want as long as you use the right size piping.
8 Ball is offline   Reply With Quote
Tags
distance , heat pump , length , line
DIY Heat Pump/Air Handler replacement hennyh HVAC 62 06-18-2012 06:11 PM
AC unit distance to out side compressor gene380 HVAC 4 06-28-2008 10:26 AM
Air Handler Fan Sporadic Sammy HVAC 5 05-18-2008 06:30 PM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 09:14 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
