Distance Between Furnace And Wall - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 08:09 PM   #1
Distance between Furnace and wall
We want to remodel our basement and I have a question I can' seem to find an answer for anywhere online. Even in the PDF code book for New JErsey.
My questions is..
How far does the back of a wall have to be from the front of the furnace? The furnace itself says 30'' but I remember reading somewhere else that it was more then that. Is it 36'' or more?
rubicon789 is offline   Reply With Quote
Old 01-13-2009, 08:22 PM   #2
The install instructions are right. As long as you can get the blower out and service the furnace you should be ok.
hvaclover is offline   Reply With Quote
Old 01-13-2009, 08:28 PM   #3
Dr Heat's Avatar
according to the national building code you need 36" for service but this is from side to side the manufacturers recombination is correct.
Dr Heat is offline   Reply With Quote
Old 01-13-2009, 08:44 PM   #4
Thanks guys, exactly what I need to know.
Williams Wall Furnace ROBBYT3 Appliances 6 02-06-2009 01:56 PM
Upgrading wall furnace Wanttodoitright HVAC 2 03-20-2008 05:57 PM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 04:05 PM
Wall Furnace change-out Calhoun HVAC 1 11-10-2006 11:01 PM
