Discontinue Use/Draining One Heating Zone - HVAC - DIY Chatroom Home Improvement Forum
Old 09-28-2013, 11:01 PM   #1
Rewards Points: 30
Discontinue Use/Draining one Heating Zone
Hey there. I have an oil-fired boiler with two heating zones. One serves the finished attic while the other serves the rest of the house. Currently I am not using the attic, so heating it seems to be a waste. The only reason I can think of to continue heating up there is to keep the PEX pipes that carry the hot water to the radiators from freezing. I figured if I can drain those pipes, I wouldn't have to worry about it. How do I go about this? Just close the shut off valve on the zone I want to drain, attach a hose to the drain fitting and open the drain? What about if I ever want to start heating up there again? Just open the valve and let the water flow into the pipes? I'm guessing that the air must be purged somehow. My radiators are only a couple years old and have no valve on them to release air. How do I get the air out? Took some photos of my system just in case. Thanks.
porkfriedrice is offline   Reply With Quote
Old 09-29-2013, 06:09 AM   #2
An old Tradesmen
Rewards Points: 7,414
You'll need to find a way to let air in the supply side to drain the attic zone. Pics don't show enough.
Old 09-30-2013, 03:48 AM   #3
Rewards Points: 30
Here's a few more photos. Not seeing any other drain valves on this end. I'm guessing I wouldn't be able to fully drain without it?
Old 09-30-2013, 04:20 AM   #4
An old Tradesmen
It can be done by letting the air vent draw air in while the loop is draining. You have to manually open the zone valve for the attic to let the air draw into that zone loop.
Adding a second heating zone benbak HVAC 1 09-24-2011 07:22 AM
2 zone heating joetab24 HVAC 20 03-09-2010 04:44 PM
Boiler heating zone not working properly ssevern HVAC 5 12-19-2009 06:05 PM
Adding new zone makapacs HVAC 0 11-26-2009 12:35 PM
need some help sorting out my new heating zone please wombosi Plumbing 3 04-23-2009 04:54 PM
