Disconnecting Central Air Conditioner - HVAC - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 10:14 PM   #1
I want to put a concrete pad under my central air units. When you disconnect the lines, do you lose all the freon or refrigerant?
MichaelJohn is offline   Reply With Quote
Old 08-08-2009, 10:22 PM   #2
Electrical Contractor
kbsparky's Avatar
Most likely. But you should be aware that disconnecting HVAC refrigerant lines is not a DIY project.
Such a job needs to utilize an EPA approved freon recovery system.
Best to consult with a licensed HVAC contractor for such a task.
-KB
Old 08-08-2009, 10:35 PM   #3
Ice Man
You can "pump down" the refrigerant back into the condenser using the discharge and suction valves. You would require a set of gauges to watch your pressures as you perform this work. Close your discharge valve and turn on your a/c. watch your pressures as your suction drops to about 5 psig then totally close off your suction valve. This isolates most/all of the refrigerant into your condenser. Your lines are now free of refrigerant your able to cut your lines out and move your a/c unit.
Ice Man is offline   Reply With Quote
Old 08-08-2009, 10:37 PM   #4
Ice Man
If your not a licensed HVAC mechanic i would not recommend performing this task.!!!
Old 08-09-2009, 05:19 AM   #5
An old Tradesmen
Rewards Points: 8,154
Since you would still have some refrigerant in the lines with that method. You would still lose some refrigerant.
Need a EPA certified tech, to open up your line set, and then reconnect, vacuum and check/adjust charge.
Old 08-09-2009, 05:19 AM   #6
biggles's Avatar
forget the disconnecting...place cinder blocks on each side of the condenser 24" out from the condenser..lift the condenser and slide some 2X4s across the blocks.oh almost forgot .......how to lift that condenser get 2 guys with lenghts of 2X4s 4' long each one holding their ends(facing each other) pinch the condenser,and lift it then you slide the 2X4s across the blocks.that should give you plenty of room to level out and slide a form in there...might have to disconnect the power but the lines can stay on that vertical rise.
Old 08-09-2009, 10:05 AM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 380
Not all freon lines have room to bend/flex and if you kink the big line then game over. Copper gets harder as it gets older so you have to be INCREDIBLY careful when lifting those units.
Old 08-09-2009, 01:07 PM   #8
biggles's Avatar
make the form outside,and pour it (4" thick) then slide it under the lifted condenser...will cut down on lifting it and those cinder blocks
Old 08-10-2009, 11:38 AM   #9
EPA allows for a "De Minimus" release of refrigerant.
Why do you need to pour concrete? I'd use a preformed pad and you should be able to raise the condensor enough to slide one in. It would be a whole lot easier then a disconnect/pumpdown/move/reconnect/braze/vacuum/adjust charge.
hennyh is offline   Reply With Quote
Old 08-10-2009, 11:59 AM   #10
An old Tradesmen
Yes they do.
But that is not a De Minimus release.
Since the EPA has regs on the level of vacuum you must pull before you open a system.
Leaving the lines with 5PSIG pressure in them, and blowing that charge, is an intentional venting.
Old 11-21-2010, 08:05 PM   #11
If your AC units is left disconnected with just electrical tape over the ends of the cut copper for a prolonged period will this cause damage?
m_kew is offline   Reply With Quote
Old 11-21-2010, 09:02 PM   #12
An old Tradesmen
It can. Depending how long it sits. Prolonged storage should have the ends brazed/soldered shut.
Old 11-22-2010, 08:30 AM   #13
its been about 1 1/2 months
Old 11-22-2010, 03:15 PM   #14
An old Tradesmen
It should have been sealed. It may or may not have drawn moisture into it. Moisture, compressor oil, and teh copper windings combine and make an acid that eats the motor windings, causing more acid to be former.
Old 11-23-2010, 08:41 PM   #15
thanks for the help, I live in a condo and the condo board had someone disconnect it without my permission because they needed to move it.
a very odd problem with central air conditioner cooldragonshome HVAC 8 06-14-2015 06:06 PM
Central air conditioner filters Jax newbie HVAC 4 11-10-2008 09:24 AM
Central vac, freezer, and gas water heater on same circuit? curls00 Electrical 7 03-10-2008 09:57 PM
winterizing a central air conditioner Buckeyefan7 HVAC 2 11-29-2005 09:11 AM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 12:47 AM
