Disconnect Stage 2 Cool (Y2) On Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 10:38 PM   #1
Question
Disconnect Stage 2 Cool (Y2) on thermostat
Last fall I read up about Aux heat on my heat pump and learned that I could disconnect the W2 wire on my thermostat to disable it. I saved literally thousands of dollars this winter doing so. I have a 2 stage cooling system, so if I disconnect the Y2 wire that activates the 2nd stage cooling, will this only run on stage 1 and use less electricity? And if so, will this harm my system in any way? I know it may not cool the house as fast, but if it saves a lot of $$, I don't mind. Any insight is appreciated. Thanks!
birdflu is offline   Reply With Quote
Old 04-11-2013, 10:41 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
low speed cooling is a dehumidification process first and foremost. might want to leave y2 connected as also your system will be running longer to achieve a set temperature on low speed only.
try it and see how it works.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
birdflu (05-21-2013)
Old 04-12-2013, 05:21 AM   #3
An old Tradesmen
Rewards Points: 6,516
When you disconnected W2. You disabled the electric resistance heat. Which uses a lot of electric.
For cooling, disconnecting Y2 won't save much if any money. Won't harm the A/c. but may mean your house could get a fair amount warmer then you want. Set the thermostat temp 2 or 4 degrees warmer then you normally would, and it will save you money on cooling.
The Following User Says Thank You to beenthere For This Useful Post:
Old 05-21-2013, 06:26 AM   #4
Thanks guys, I will leave the AC alone and keep AUX disabled in the winter months. With a 160 yr old house, I'm always looking for ways to stay as efficient as possible. Thanks again.
Old 05-21-2013, 06:41 AM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Some setups have separate disconnects for the heating elements, thus, eliminating the need to actually disable the AUX terminal.... just a thought. Would be easier to re enable the AUX heat if so needed on colder nights.
Tags
multi-stage thermostat
I need help wiring my thermostat. batalbj1 HVAC 3 03-28-2013 11:30 PM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Bryant Plus 90t with New Thermostat mikeosoft HVAC 8 04-03-2011 07:19 PM
Waterfurnace Hydronic Water and Air Heatpump Thermostat Configuration JDForinger HVAC 8 12-05-2010 05:57 PM
Multi stage heat pump thermostat marriedmanw HVAC 2 02-28-2010 05:12 PM
