-   -   Disconnect Stage 2 Cool (Y2) on thermostat (http://www.diychatroom.com/f17/disconnect-stage-2-cool-y2-thermostat-176904/)
birdflu 04-11-2013 09:38 PM
Last fall I read up about Aux heat on my heat pump and learned that I could disconnect the W2 wire on my thermostat to disable it. I saved literally thousands of dollars this winter doing so. I have a 2 stage cooling system, so if I disconnect the Y2 wire that activates the 2nd stage cooling, will this only run on stage 1 and use less electricity? And if so, will this harm my system in any way? I know it may not cool the house as fast, but if it saves a lot of $$, I don't mind. Any insight is appreciated. Thanks!
Doc Holliday 04-11-2013 09:41 PM
low speed cooling is a dehumidification process first and foremost. might want to leave y2 connected as also your system will be running longer to achieve a set temperature on low speed only.
try it and see how it works.
beenthere 04-12-2013 04:21 AM
When you disconnected W2. You disabled the electric resistance heat. Which uses a lot of electric.
For cooling, disconnecting Y2 won't save much if any money. Won't harm the A/c. but may mean your house could get a fair amount warmer then you want. Set the thermostat temp 2 or 4 degrees warmer then you normally would, and it will save you money on cooling.
birdflu 05-21-2013 05:26 AM
Thanks guys, I will leave the AC alone and keep AUX disabled in the winter months. With a 160 yr old house, I'm always looking for ways to stay as efficient as possible. Thanks again.
stickboy1375 05-21-2013 05:41 AM
12 Attachment(s)
Some setups have separate disconnects for the heating elements, thus, eliminating the need to actually disable the AUX terminal.... just a thought. Would be easier to re enable the AUX heat if so needed on colder nights.
