Discharging Ac Unit - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 09:18 AM   #31
Rewards Points: 582
Originally Posted by quanchai View Post
Well i want to fix this by my self i got a vacum pump + a empty gas recovey tank
will i lose oil from the compressor if i use this GREEN method ?
sorry you can't ...I have a hammer and a chisel I want to build a garage....you get the point I can't.....don't mean to be rude ..but Iam done with this post at this point....have a good day...
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (08-05-2012)
Old 08-05-2012, 09:31 AM   #32
Just Yes or No thats all you need to say
quanchai is offline   Reply With Quote
Old 08-05-2012, 09:35 AM   #33
An old Tradesmen
Rewards Points: 6,928
Yes you will lose oil. And it will probably require a recovery machine o get all the refrigerant out. unless it very low on charge.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (08-05-2012)
Old 08-05-2012, 09:55 AM   #34
Rewards Points: 1,216
" People have been telling you NO since post #2 and you just don't get it or want to hear it, NO, NO NO, you can not do it call an Air Conditioning Company". Sorry about the straight forward attitude, hoping you get the message.
PS: Most of the people that have been answering your questions are PRO'S with several hundred years experience if you added up all their time. So listen up.
COLDIRON is offline   Reply With Quote
The Following 2 Users Say Thank You to COLDIRON For This Useful Post:
ben's plumbing (08-05-2012), hvactech126 (08-05-2012)
Old 08-05-2012, 12:39 PM   #35
You can't recover refrigerant with a vacuum pump and a tank. The only way to do it is to use a recovery machine. As others have said, if you're in the business then buy the tools to do things the right way. If you're not, then hire someone to do things the right way.
scottmcd9999 is offline   Reply With Quote
The Following 3 Users Say Thank You to scottmcd9999 For This Useful Post:
ben's plumbing (08-05-2012), COLDIRON (08-05-2012), hvactech126 (08-05-2012)
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 04:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 03:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 07:50 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 09:33 PM
