08-03-2012, 11:05 AM
#16
Discharging ac unit
I don't know what the "ghetto way" is. The only legit way to remove refrigerant is to reclaim/recover it.
Why would you NOT want to store it with refrigerant? Doing so will keep the system in much better shape, and would be a lot easier on you.
08-03-2012, 01:12 PM
#17
Discharging ac unit
Why don't you just pump it down and store it with the refrigerant in it for now. Nothing wrong with that as that is how they usually come from the mfg. Do what you need to do with the new system and then decide how to recover/discharge the refrigerant from the old unit later at your leisure.
Live long and prosper.
08-03-2012, 06:08 PM
#18
Discharging ac unit
Ok but can some one just tell me why oil comes out with the gas ???
08-03-2012, 06:11 PM
#19
An old Tradesmen
Discharging ac unit
Because they are mixed together. As they should be, to assure oil return to the compressor.
The Following User Says Thank You to beenthere For This Useful Post:
08-03-2012, 06:17 PM
#20
Discharging ac unit
so if recovering the gas would the com not lose oil ?
PS
how do you add oil to home AC compressors ?
08-03-2012, 06:34 PM
#21
Discharging ac unit
The correct way would be to remove all the oil from the compressor then put the specified amount on the compressor tag back in. Those mini splits are touchy. You can't just add/remove oil or refrigerant willy nilly.
The Following User Says Thank You to Marty S. For This Useful Post:
08-05-2012, 06:20 AM
#22
Discharging ac unit
there must be a way to add oil ?
08-05-2012, 06:51 AM
#23
Discharging ac unit
There are pumps you can use to force oil into the system through your charging hoses, but it's hardly a precise process, and over-oiling can cause problems too. Almost all residential systems are semi-hermetics, which basically means they are sealed systems, with the only openings being those designed for charging and checking pressures. There are no oililng ports for the refrigerant system.
The Following 2 Users Say Thank You to scottmcd9999 For This Useful Post:
08-05-2012, 06:53 AM
#24
An old Tradesmen
Discharging ac unit
I think you mean hermetic. Haven't seen a semi hermetic on a resi system.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
08-05-2012, 07:05 AM
#25
Discharging ac unit
Doooh ... you're right, got the terms backwards.
Didn't Carrier make a low speed residential system with a semi-hermetic? I remember dragging one of those beasts out of a back yard many years back. One of the heaviest residential condensers I ever dealt with - my back remembers it to this day! Might have been one of the old low speed compressors, though, now that I think about it. Those were monsters too.
I know Chrysler had some old tanks, but I don't recall those being semi-hermetic.
08-05-2012, 07:10 AM
#26
An old Tradesmen
Discharging ac unit
Carrier did a lot of strange things over the years. So I can't say they never had a semi in a resi. I just don't recall one. I'm senile though, so that doesn't mean much. LOL
The old compressors were made like a tank, to last for a long time back then, so they were heavy.
08-05-2012, 09:28 AM
#27
Discharging ac unit
Lets say you over charge a unit with gas and you want to let some of the gas out
this happend to me ones so i had to purge the over charged gas out and with the gas oil came out (TO MUCH OIL)
08-05-2012, 09:41 AM
#28
An old Tradesmen
Discharging ac unit
Even Kuwait signed the Montreal Protocol.
You don't purge out extra refrigerant, you recover it.
#29
Discharging ac unit
ok I have listened to this post long enough ..have to say this....if you are a hvac mechanic with proper tools and equiptment you would not overcharge a unit..you would not release freon into the air..and i know you said you were in tim buck too...lets say you call a service company and wait ..before you end up hurting yourself...IMO ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
08-05-2012, 10:14 AM
#30
Discharging ac unit
Well i want to fix this by my self i got a vacum pump + a empty gas recovey tank
will i lose oil from the compressor if i use this GREEN method ?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
