08-01-2012, 03:30 PM
#1
Disabling radiator
Hi all,
I haven't had much luck with completely disabling the radiators in my house by turning the knob (1-8) all the way off. For some reason, it's not guaranteed to not produce any heat, though maybe this is why there is no "0" indicator. The heaters apparently measure the outside temperature and use that to gauge how much heat to produce, but I'm fairly certain the knob controls the intensity, so I'd hope I can completely disable it.
My landlord told me that if I swivel the valve (probably not the correct term for it, sorry) by 90 degrees, then that will disable the radiator. In the first image, you'll see the valve on the right side is in the normal position. In the second image, I've rotated it 90 degrees. Obviously the radiator shouldn't be doing anything in the summer, but I cannot take any risks as it is located right next to my guitar. I'm hesitant to use this method until I've heard some confirmation from non-landlord-type people.
Thanks,
Sasha
08-01-2012, 06:40 PM
#2
Disabling radiator
is the radiator hot to the touch in the middle of the summer.that is the vent your turning on the right .the boiler might be sensing outside air to run but not to produce for heat ...maybe hot domestic water?shutting the larger valve on the lower left shuts the steam feed into it...looking down on it go full CW to close full CCW to open.
08-01-2012, 07:21 PM
#3
An old Tradesmen
Disabling radiator
You have a steam boiler. Post pics of it.
08-01-2012, 08:51 PM
#4
Disabling radiator
yep that is a steam boiler..... as beethere said pictures will help.. ..can't read anymore..
08-01-2012, 08:53 PM
#5
An old Tradesmen
Disabling radiator
Originally Posted by ben's plumbing
yep that is a steam boiler..... as beethere said pictures will help....its not suppose to be producing heat in the summer time ..unless where you are located its cold???
Could have a tankless coil in it, or side arm heater. And the aquastat could be set too high.
The Following User Says Thank You to beenthere For This Useful Post:
08-01-2012, 08:57 PM
#6
Disabling radiator
if thats the case haven't seen that in awhile..well at least not here in my neck of the woods...
08-01-2012, 09:12 PM
#7
Professional
Disabling radiator
maybe i'm wrong, but I see a hand valve on the left side of the radiator in pic 1.....
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The Following User Says Thank You to hvactech126 For This Useful Post:
08-01-2012, 09:15 PM
#8
Disabling radiator
nope your right he said when he turns it ..it dosen't shut the radiator off.....
08-01-2012, 09:17 PM
#9
Professional
Disabling radiator
but that is not what he is showing that he is turning......
#10
Disabling radiator
hey guys did he turn the vent 90 degrees....read post ...i think he did and not the valve....
The Following User Says Thank You to ben's plumbing For This Useful Post:
08-01-2012, 09:24 PM
#11
An old Tradesmen
Disabling radiator
yep, he turning the vent. He first tried turning the vent's vent opening. then turning the vent itself 90°. probably misunderstood his landlord.
Still, the problem is why is the boiler making steam this time of year.
08-01-2012, 09:26 PM
#12
Disabling radiator
I think his post said it was not being used at this time..but wanted to be sure he could shut it down???..
08-01-2012, 09:28 PM
#13
Disabling radiator
just read post for the 4th time     not sure
08-02-2012, 01:17 AM
#14
Disabling radiator
Thanks for the replies.
To end the confusion: during the heating season, I turned the numbered knob on the bottom of the vent to try turning off the heat, which didn't work. So, my land-lord suggested turning the entire vent 90degrees (which is pictured in the 2nd image). Because it is summer, I have not yet tested this (and don't really want to because it seems risky).
My friend just pointed out the valve on the LEFT, the one that some of you pointed out, and told me to turn it fully CW to prevent any steam from getting in. So, that is what I've done and I trust him. Though of course, I won't know if it works or not until heating season.
I will try to find the boiler that you guys mentioned and take some pics, though I doubt I could tamper with it as I live in an apartment building.
-Sasha
08-02-2012, 05:37 AM
#15
An old Tradesmen
Disabling radiator
The vent(device on the right) is adjustable to increase or decrease teh amount of heat you get from the rad. the valve on the right is to shut off the heat completely.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
