Disable Emergency Heat On Digital Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2012, 03:39 PM   #1
What is the code, and proper setting, to disable the Emergency Heat on an American Standard ACONT800 Digital Thermostat? I found an install manual that has some basic codes but it does not provide the three digit EMHEAT code.
I want to run my heat pump off of my generator -- no issue there. But the air handler is on a 60AMP breaker to accomodate the electric furnace. I don't need the furnace/EMHEAT, but I do need the airhandler blower to run without the possibility of the EMHEAT kicking on and overloading my generator.
Thanks.
tlloydusmc is offline   Reply With Quote
Old 11-03-2012, 09:11 PM   #2
An old Tradesmen
Rewards Points: 6,470
There is no code to disable the aux heat. However, you can get an outdoor temp sensor and lock out the aux above X temp. So when your power goes out, you just set the lock out temp below current temp by 5 or 10 degrees.
The Following User Says Thank You to beenthere For This Useful Post:
tlloydusmc (11-04-2012)
Old 11-03-2012, 10:23 PM   #3
you could just disconnect t stat wire for aux/emergancy heat from the t stat base
hvacjunkie is offline   Reply With Quote
Old 11-04-2012, 10:21 AM   #4
AKA HVACTECHFW
Rewards Points: 1,208
you would also have to disconnect it at the heat pump so that it doesn't call during defrost. The best option is to disconnect the w1,w2,w3 wire(s) at the air handler.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 11-04-2012, 10:49 AM   #5
Thanks! If I disconnect the W1, W2, W3 wires, will the system still defrost properly? If not, can I leave the "W" connections in place and just disconnect the power source connector inside the air handler to the heater strip? Will disconnecting this source have other unintended consequesnces? I just want to stop the electric heat from firing up without adversely affecting other system operations.
Old 11-04-2012, 12:39 PM   #6
An old Tradesmen
If you disconnect the power to the heaters. then when it defrost you get nice cold air blowing out the registers for 5 to 15 minutes while it defrost. Some people don't mind that, others do.
Old 11-04-2012, 06:56 PM   #7
AKA HVACTECHFW
As BT stated it will defrost just fine it is just that the air put out from the AHU during defrost will be cold. But this is the ONLY way to keep the strip heaters from turning on while running on the generator so it would be worth it in my opinion. Defrost does not happen that often unless there is something wrong with the system.
IT IS WHAT IT IS
Old 11-04-2012, 07:55 PM   #8
Thanks BT & hvactech. I can live with some cold air...will disconnect W-1, 2 & 3 at the air handler. Apprceiate the assist.
Tags
acont800 , emergency heat
Frigidaire heat pump thermostat options zootjeff HVAC 6 03-24-2011 05:26 AM
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 09:18 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 02:17 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
