Dirty Furnace-how To Clean? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 10:31 PM   #16
An old Tradesmen
Rewards Points: 6,880
Originally Posted by hvaclover View Post
>>she did say the coil wasn't being used...duuhh..I am thinking heat pump.
I didn't think of it till she said it slide out easy.
Old 10-12-2008, 10:36 PM   #17
Originally Posted by beenthere View Post
A quick question.
Since you don't have A/C. Meaning there are no external lines hooked to the coil.
Why not just remove the coil. Store it in a safe place.
With the coil removed. Your blower motor won't work as hard to move the air.
Good point. Then the house will heat up faster.
The key word here is store in a VERY SAFE place.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-12-2008, 10:41 PM   #18
This reminded me of some thing else that we over look.
How many times have you lost schrader caps?
Here's the solution: Screw them on to your hose holder on your manifold set.
hvaclover is offline   Reply With Quote
Old 10-12-2008, 10:47 PM   #19
An old Tradesmen
Being a VS blower, it may or may not heat up faster. Depends how restrictive her duct system is.
But, it will lower the electric the blower uses.
Old 10-12-2008, 10:48 PM   #20
An old Tradesmen
I do that 50% of the time.
The other 50% of the time, I lose the caps.
Old 10-12-2008, 10:56 PM   #21
Is the 'V' shaped thing with the fins on it the AC coil? And removing this would help the blower to not work as hard and lower my electric bill? I would feel more comfortable hiring a professional to do that for me, as I'm not familiar with the insides of furnaces, and to be honest, it scared me half to death to do this today ! Because the furnace does sound so much better, would it be okay to just leave it as it is?
Debbie
luv2sipt is offline   Reply With Quote
Old 10-12-2008, 11:05 PM   #22
I thought was my original idea.
Is there any thing you don't know?
Old 10-12-2008, 11:07 PM   #23
Debbie
No prob, if it make you feel more sequre.
Old 10-12-2008, 11:11 PM   #24
An old Tradesmen
That was taught to me by an old timer, that was old when I worked with him many many years ago.
I think that now makes him an old old timer.
Unfortunately, there is way too much that I don't know, and I don't have the time to learn all of it.
Every time you learn one thing. They add 2 new things you don't know about.
Old 10-12-2008, 11:15 PM   #25
An old Tradesmen
Debbie
Its fine to leave the coil in.
Old 10-14-2008, 09:06 AM   #26
Yes, that is the A/C coil. The suggestion to remove was an an efficiency improvement. You system should operate just fine with it left in.
Next time you have someone come in to give your system a periodic checkup (and you should, I consider myself pretty knowledgeable, but I just like someone else seeing if I overlooked something), ask them to yank the coil and prep it for storage. Put it somewhere it won't rust, get dusty or get banged up.
dac122 is offline   Reply With Quote
Old 10-14-2008, 10:27 PM   #27
That sounds like a good idea to me, too. I'm for anything that will save $$, especially during times like these! Thanks again, everyone-you all are great!
Debbie
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
Add-on Wood furnace billmac HVAC 3 06-18-2008 09:17 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
