Old 02-02-2009, 07:44 PM   #1
Default Direction of Airflow for Heat Pump Condenser
After an ice storm we had this past week, I had damage to the condenser fan on my outside heat pump unit. I purchased a new fan today and replaced the damaged one, then put everything back together. Everything is running smooth but I am worried that I may not have installed the fan blades in the right direction. With the outside unit running, cold air is blowing out of the top of the unit. We have heat coming out of the inside vents, but should the outside heat pump be sucking air in, or blowing it out?
techster82 is offline   Reply With Quote
More On This Topic
Nothing can ruin your summer or winter like finding you have no heat or air conditioning because your heat pump is malfunctioning. If you have to buy a new heat pump, an uncomfortable season can turn into an uncomfortable year. However, heat pumps are... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be answering the question how does the cooling system work. The primary job of the cooling system is to keep the engine from overheating as you are driving. As liquid passes through... Read More »
Hi welcome back to expertvillage.com. You could see here this is the clean fan right over here. I have just finished brushing it and blowing some compress air in it. Okay next thing that we are going to do is the heat sink, or the CPU right over here... Read More »
You may notice sometime that water is dripping out of a tube in a place that it’s never dripped before, and it’s a pretty annoying thing and it may be getting your porch or door wet. Well, there’s a reason for that. It’s called... Read More »
Solar power has come a long way in the last few decades. What once seemed like an ecological pipe dream has become a viable means of producing electricity. To save money on your electric bill and preserve precious environmental resources, you should... Read More »
Condenser Fan Stop/Start - Heat Pump mkurley HVAC 5 02-04-2009 04:06 PM
Heat pump condenser fan missing: how do I know what to replace it with? Ptron HVAC 9 11-29-2008 02:46 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 08:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 11:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 06:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
