Direct Vent Water Heater Location - HVAC - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 09:49 AM   #1
Rewards Points: 640
direct vent water heater location
I need to move my water heater as we are building around the area it is in, and its in direct line of a wall that will go in... right now the vent runs straight out from it to the rim joist and out the house only 1 elbow total
where can I place the exaust vent in relation to things outside? where I want to move it, if I run the vent straight it will be right beside the AC unit, or can I run a line from where it will be moved and join it to the old line as long as it slopes down towards the water heater? that would create one elbow at the top of the heater, one elbow at the end of the first run then up about 1 ft then another elbow that turns 90 degrees to connect to the existing exaust vent pipe....
the manual says a max 3 elbows, but says nothing about turns in the pipe so im not sure on that one and using their calculations, i'm within the max length, i have to go 15 ft out and 8 ft back and with the 3 elbows calculated in im still within their max 40 ft....
any issues or anything I should know about this?
BlueBSH is offline   Reply With Quote
Old 09-14-2010, 04:17 PM   #2
An old Tradesmen
Rewards Points: 6,548
Most water heaters want the flue sloped away from the water heater.
Sounds like you'll be ok.
A pic or drawing would help.
Old 09-14-2010, 04:27 PM   #3
Rewards Points: 640
here's a simple drawing, tan is the current location where the pipe goes straight up then straight out, red is the new location with the green being the new 3" pipe for the venting
Old 09-14-2010, 04:31 PM   #4
An old Tradesmen
Should be fine.
Old 09-14-2010, 04:34 PM   #5
Rewards Points: 640
Originally Posted by beenthere View Post
Should be fine.
that's what I was thinking when I read the manual's specs for the vent, but just wanted to be sure someone else agreed with me on this
Old 12-17-2012, 06:11 AM   #6
Post
simple diagram water heter.
masood786 is offline   Reply With Quote
Old 12-17-2012, 12:29 PM   #7
Rewards Points: 1,294
You are replying to a 2 year old post. do you have a question that needs answering?
danpik is offline   Reply With Quote
Old 12-17-2012, 02:20 PM   #8
Roofmaster
Rewards Points: 2,172
How do you turn the pipe without an elbow????
Tankless Water Heater welshie Plumbing 12 03-03-2010 01:46 PM
Hot Water Heater Venting...need suggestions flyhop Plumbing 11 01-27-2010 01:50 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
Securing vent hood to top of water heater? darsunt HVAC 1 07-01-2008 09:59 PM
