-   -   direct vent water heater location (http://www.diychatroom.com/f17/direct-vent-water-heater-location-81404/)
BlueBSH 09-14-2010 09:49 AM
I need to move my water heater as we are building around the area it is in, and its in direct line of a wall that will go in... right now the vent runs straight out from it to the rim joist and out the house only 1 elbow total
where can I place the exaust vent in relation to things outside? where I want to move it, if I run the vent straight it will be right beside the AC unit, or can I run a line from where it will be moved and join it to the old line as long as it slopes down towards the water heater? that would create one elbow at the top of the heater, one elbow at the end of the first run then up about 1 ft then another elbow that turns 90 degrees to connect to the existing exaust vent pipe....
the manual says a max 3 elbows, but says nothing about turns in the pipe so im not sure on that one and using their calculations, i'm within the max length, i have to go 15 ft out and 8 ft back and with the 3 elbows calculated in im still within their max 40 ft....
any issues or anything I should know about this?
beenthere 09-14-2010 04:17 PM
Most water heaters want the flue sloped away from the water heater.
Sounds like you'll be ok.
A pic or drawing would help.
BlueBSH 09-14-2010 04:27 PM
1 Attachment(s)
here's a simple drawing, tan is the current location where the pipe goes straight up then straight out, red is the new location with the green being the new 3" pipe for the venting
beenthere 09-14-2010 04:31 PM
Should be fine.
BlueBSH 09-14-2010 04:34 PM
Originally Posted by beenthere (Post 501087)
Should be fine.
that's what I was thinking when I read the manual's specs for the vent, but just wanted to be sure someone else agreed with me on this
masood786 12-17-2012 06:11 AM
simple diagram water heter.
danpik 12-17-2012 12:29 PM
You are replying to a 2 year old post. do you have a question that needs answering?
jagans 12-17-2012 02:20 PM
How do you turn the pipe without an elbow???? :wallbash:
